Results 1 to 12 of 12
Thread: Tran Fast learn procedure won't work with aftermarket stalls - Any ideas?
    Mar 2009
    Earth
    213
    I've been able to do this procedure successfully on STOCK stalled cars, but cannot get this process to complete on any of the cars I've installed a 2800rpm (or higher) stall converter in. I've tried going into the VCM and lowering the idle down, does nothing.
    What's the trick to make this work with an aftermarket converter installed?
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,021
    if anything you may have to raise the idle. The ones i did was not seeing enough input shaft speed because of the converter. If you can get it to learn, you may just have to do it the old fashion way and make a few wot shifts, and no brake decels
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Mar 2009
    Earth
    213
    Quote Originally Posted by mbray01 View Post
    Thank you for the input sir.
    I'd rather try to get this procedure to work first, before trying anything else. Before realizing how important this was we previously hurt a few freshly built 6L80's. Since doing these fast learn procedures we've had no issues.
    So you're suggesting raise the idle and re-test?
    Dec 2013
    Slidell, La.
    1,021
    thats what i had to do, the loose converter was not spinning input shaft fast enough. was just throwing that slow learn process out as when these trans first came out and the software wasn't correct in the scanners we were being to told by gm engineering to learn the units old school. hold to floor on accel, and do not touch the brake while slowing and allowing to vehicle come to a crawl by itself. anyway, I do believe you are experiencing the same problem I had and the input speed was not sufficient for the tcm to see the rpm drop during the clutch test.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Tuner seven ends's Avatar
    May 2007
    Houston, Tx
    155
    I couldn't get the fast learn to work on my built 6L80 with triple disk 2800 stall. But connecting to do the trans adapt reset and preset made a huge difference in learning time and I do that after every significant transmission change now. I read elsewhere herein that it forces it to start learning with your new programming because everything else has been cleared.
    2010 Avalanche 4WD; AES 390; Mast LS3 heads; VVT Cam; ported TVS2300; Overdrive 8 rib pulleys; 2.7 snout pulley; ID1000; LS3 TB; WB 450; Twin MM cans; built 6L80; CircleD Triple Disk, CSR flexplate; Trucool 40K; Aeroforce Dual; AFX
    Dec 2006
    Pensacola, FL
    496
    Quote Originally Posted by seven ends View Post
    What's the procedure for the adapt reset and preset? TIA
    Tuner in Training lablkv6z's Avatar
    Jun 2011
    Broussard, Louisiana
    12
    Exclamation Trans Fast learn guidance please
    Hey guys, this thread pertains to the issue that I am working with right now, so I will add to it, for those who are in the same boat.
    Cliff notes: Cammed LS3, 3800 Stall converter, Trans adapt reset/preset/fast learn (failed), Now only forward gear is 4th, that's it.
    I'm in the process of tuning my 2008 Corvette A6. I made some changes to the Trans/Torque Management/Upshift/Torque Factor tables and the Trans/Shift Pressures/Adaptive/Oncoming Pressure Preset tables so I figured a trans adapt reset/preset was in order.
    I followed the directions in the Fast Learn and Trans Cleaning Sticky: https://forum.hptuners.com/showthrea...ght=fast+learn
    After tapping the Adapt reset/Adapt preset/and initiating the Fast learn in the VCM scanner, the function fails while calibrating drive.
    I've read that with the higher stall TC?s, the input shaft RPMS aren?t high enough for the testing, which causes the Fast Learn to fail.
    So now since I?ve reset the trans adapts, when I put the shifter into Drive, I can see in the scanner that it goes immediately into 4th gear and stays there. It?s the only forward gear I have in Drive.
    When I put the shifter into Sport, I can see on the heads up display that when the car isn?t moving, it?s flashing between 2nd and 3rd gear, as soon as I move forward, it goes directly to 4th and stays there.
    I've tried adjusting my idle rpms in the tune down to 625rpm and also 1750rpm, and do the Fast Learn but both failed.
    I've also reflashed to a completely stock trans tune with the same failed outcome.
    I've driven the car for about 100 miles and it still stays in 4th gear.
    Any suggestions are welcomed, thank you all.
    -T
    Car information, 2008 Corvette, 6L80E, Cammotion mild camshaft, boltons, Circle D 3800 multidisc TC
    A6 Trans fast learn fail.hpl
    vve7 trans reset failed stuck 4th gear.hpl
    vve7 trans adjust.hpt
    C6 NA graphs.Graphs.xml
    C6 NA trans channels.Channels.xml
    Aug 2021
    570
    The fast learn doesn't work with high stall TC's.
    In fact fast learn does not work on all cars in factory trim either (it works as it should in some/most cases, but many have found issues on stock vehicles).
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Jun 2011
    12
    Thanks for the feedback.
    I will try flashing the stock trans tune once again and try clicking the Trans Adapt reset, Trans Adapt preset and see if it will actually go through all of the gears instead of just going straight to 4th.
    I would try using the tech2 software with a VCX NANO from amazon... you can do a lot of functions with this that the hptuners module cannot
    goatrope garage has a detailed video on accessing BCM, TCM, canbus operations, clearing and reseting sensors, etc, etc...
    search his YT for...Cheap GM ScanTool,
    Jun 2011
    12
    Exclamation
    Quote Originally Posted by alabastarbastard View Post
    Thanks for the information. We ended up using one from a buddy at the dealership. When he read it, it stated that the trans tune was stock which was odd. He reflashed the trans tune to stock any ways to try and it was still doing the same thing.
    Contacted another locally know tuner and we worked and tried multiple things. Then I set everything in Torque Management back to stock (including the ECM side), and guess what, it shifted like normal again!
    So after figuring out it was something in the torque management ECM side, I slowly back tracked, and figured it was one cell that was throwing the trans into the "limp mode".
    Engine/Torque Management/General/Traction Control System/Max Torque. This cell is 479 lb ft, I maxed it out and it didn't like it. I found that the highest I could set it was 481, anything higher throws it in "limp mode".
    Now even though this is under TCS Method, I find that whenever I am making a pull and it gets to 479 lb ft, the ECM pulls timing/something else and restricts power causing loss of momentum. Trying to work around this and maintain TM.
    I've found that this is an issue with the 07/08 6L80E TCMs in the C6s (possibly G8s as well). I'm still open to guidance guys if ya'll have any suggestions. Thanks. BTW I purchased an authentic US GM Tech 2 last night for future use.
    -T
    Jun 2011
    12
    Following up, after adjusting the Virtual Torque tables in Beta, all is working as it should now. Thanks guys for the help.
