Thread: 2014 Caprice PPV HP Tuners not reading PCM/TCM
    Sep 2011
    27
    I have a 2014 Caprice with an E38 PCM. I had the car running after doing a write entire with a stock caprice tune. I had to do this due to swapping to another PCM. I was having drivability issues and throwing a P0615 code, so I got another PCM and did the same write entire. I then started to get a U0100 code, and during this time I was having issues with the car running (possibly a bad maf). Following this, I took my battery terminals off and left the car for two days while waiting for my new MAF to come in. When I put power back to the car, I was unable to start it and HPT will not read the ECM or TCM. It says controller unlock timed out. I can only read the cars FSCM. Does this sound like both my ECM and TCM got bricked from the battery being off? I'm at a loss and considering dropping the car off at Chevy and have them check the modules.
    14,071
    If it was me I would have had the new to you computer flashed with a GM tool to the VIN/OS you wanted. HP Tuners can't flash every segment when swapping computers and perhaps it's possible that something didn't work right and now you have problems.
    Sep 2011
    27
    Issue has been resolved. Not a tuning/bricking issue.
    Oct 2019
    Any Update? What was the fix? Having the same issue now.
