Results 1 to 6 of 6
Thread: How to add a clear space between channels.
    Mar 2018
    451
    I've noticed a lot of screen shots have a space between series of channels. I cannot figure how to do this.
    Thanks for the help
    14,066
    Going off memory here, right click a channel or highlight a whole section of channels and then click move down.
    This will create a space.
    Mar 2018
    451
    Doesn't work. It just swaps the selected channel with the one below it, no space
    2,760
    Try selecting all the way down the channel list. Or start at the bottom and move them one at a time.
    Mar 2018
    451
    Yep, this works, thanks.
    Jul 2023
    Beaumont, AB
    Just wanted to drop a line to clarify how this works. I had this issue and read multiple threads that were kind of right but not clear.
    You need to highlight all the channels below where you want the space. Then right click and select move down. You may also select all channels, below where you want the space, up to the next space in the channels. This will also create a space.
    Highlighting one channel and selecting move will just swap it with the channel above or below. Also selecting a group of channels in the middle of channels will not work. You have to select all channels to the end or until the next space on channels, to create a blank space above the highlighted channels selected.
    Cheers.
