Hi
I am wondering if anyone has a startup tune for an install that ?i will be doing shortly?
vehicle is a 2015 silverado w/ lt1 5.3l
I will bw installing a 2.9l whipple on an otherwise stock truck.
tia
Hi
tia
2003 MY Z06 3.3 liter whipple ...sold at around 1000 rwhp
wip 2015 Silverado w/2.9 Whipple (phase 1 completed) phase 2 in the works
Did you buy the tuner kit? I will attach the tune that was supplied by whipple that came with the supercharger.. Let me just tell you after i custom tuned it, it was a beast compared to the tune that came with it but it will be a safe starting point at least. The one i did was also a 2015 5.3 Silverado and 2.9 Whipple so it should be very close.
I definitely can but i recommend to use it as reference only because i installed a smaller pulley than what comes originally with the supercharger and also have a different exhaust setup. The one i already posted was the tune that comes from whipple, only thing changed was i decreased 4 degrees of timing for a safe startup tune.8. final tune.hpt
Yes. Pulley is a 3.875. Its making 10 psi but i am a 6000+ feet above sea level. Im sure at lower altitude it would make significantly more boost.
It has not been on the dyno.
And yes the map sensor is on there but the fueling is controlled with the maf only
ok, thx again
Do you have the whipple file it will not let me download
