Results 1 to 15 of 15
Thread: e85 cold start issues E40
    Jan 2016
    riverside calif
    23
    Need Help e85 cold start
    doesn't get below 38 degrees lately runs really good after it starts but i have to crank it too many times to get it running after it starts the first time in the morning it starts right up after that all day.
    need some help.
    as soon as it starts my wideband goes to .62 within 5 seconds its at .80 as it warms up goes up to .98 its at1.22 cranking
    2006 GTO ls2 procharger 1000cc fic injectors kenne belle boostapump 425 lph walbro pump
    Jan 2016
    riverside calif
    23
    my wideband numbers are wrong in my first thread. they are 1.22 cranking .62 startup and within 5 seconds go to .90 i can attach my startup log
    Tuning Addict
    6,903
    Only glanced at a couple of things - put your open loop tables back, your cranking fuel table back and then lower your crank timing while ramping up to higher timing with the rpms. See where you're at after that and go from there. I only looked at those. Didn't verify any inj or other tables.
    ~Greg Huggins~
    8,106
    Returnless or boost referenced? What fuel pressure? FIClinic or FIConnection? Link to datasheet you used?
    Jan 2016
    riverside calif
    23
    its return less
    Thanks CHuggins for looking
    Jan 2016
    riverside calif
    23
    thats the way my open loop tables were before i started the flex tune .
    it had the procharger on it when i bought it and that tune it ran good on gas.
    i have an OEM 2006 gto file i can copy the open loop from
    8,106
    Quote Originally Posted by erichoshaw View Post
    its return less
    What fuel pressure?
    Short Pulse Adder table is still stock, that one got skipped. Don't know what it should be because it's still 50/50 which of the two companies' injectors you have.
    [ECM] 12560 - IVT Weighting Coefficient looks weird - that should be 1/2 of stock, and then also not one single value all the way across since you've done flex fuel.
    The non-scaled version should be 7.921875 8.3828125 8.84375 10.2265625 11.609375. 1/2 that would be 3.9609375 4.19140625 4.421875 5.11328125 5.8046875.
    Jan 2016
    riverside calif
    23
    returnless fi clinic 58lbs
    Jan 2016
    riverside calif
    23
    when i had their short pulse adder in it it wouldnt even idle at all it would start but was way rich and died at idle.
    it had bosch blue injectors before so is all my scaling off now when i installed these because i didnt use stock tables
    8,106
    So... your plan is to leave it scaled wrong so that it runs better with the wrong injector data?
    Best of luck. I'm out.
    Jan 2016
    riverside calif
    23
    i will change those things and test it tomorrow
    Thank You for the help
    Jan 2016
    riverside calif
    23
    all my open loop tables are set at 10.0 ist that wrong too?
    i will test it tomorrow and get back and post the log and file
    Jan 2016
    riverside calif
    23
    i changed the short pulse adder and the IVT values
    Aug 2020
    335
    Don't forget to set the cranking fuel table back to stock.
    Jan 2016
    riverside calif
    23
    e85-cold-start-issues-E40
    started great first crank
    here is the log and file
    thanks sooo much
    i have been tuning old school (no ecu) for 40+ years this is a learning curve but i love learning i really appreciate you guys taking the time to help i will keep posting
