Thread: Baro Code P2230 2018 Camaro ZL1
    Mar 2023
    I have a 2018 Camaro ZL1 A10 with a Texas Speed 427, cam, longtubes, PRC heads and a maggie 2650 blower on it, stick upper 90mm pulley on it. The car has a 103NW TB, and a big gulp Rotofab intake (some background info on the car). Car has been running fine and been tuned. The alternator kicked the bucket and I replaced it about a week ago with a brand new GM one. However a couple days ago driving home from work after a hard pull the dash displayed "ENGINE POWER REDUCED" and an SES light popped. So when I got home I plug in my HP Tuners and scanned the DTC codes and getting
    0x7E8: P2230 - Barometric Pressure (BARO) Sensor Circuit Intermittent (SES, Pending, Current, History).
    The car runs fine, AFRs are fine, no rough idle, nothing. I attempted to reset the codes and it comes right back. I disconnected battery let sit and then plugged in and after I drive comes right back and reduces engine power. I looked at the MAF and checked connections they are fine, I looked at the MAP and checked connections and it was kind of tight in the back from the main engine harness stretching around the maggie and I used zipties on the main harness to draw it up and give that MAP sensor wire behind the blower some slack. STILL COMES BACK!!! What the heck? Is there something in the tune that needs to be disabled? Can you disable this code and not affect the tune? Do you need BARO for the tune? Just need some help because this is getting VERY frustrating!
    Tuning Addict
    7,183
    Barometric pressure sensor on the lt4 was originally attached to a bracket that was mounted to the blower lid. You either have a wire coming apart or poor terminal tension from the alternator replacement. Find where the sensor was relocated to and go from there.
    ~Greg Huggins~
    Mar 2023
    OK so then its this sensor (this is on the driver side close to TB)? Its been tapped in from the hose from my mighty mouse catch can to the supercharger inlet. So this shouldn't be tapped off this line it should be hanging in free air??
    Tuning Addict
    7,183
    This is a corvette, but just a quick google search - https://www.corvetteforum.com/forums...-sensor.htmlIt should be to open air.
    ~Greg Huggins~
