Stock L83 with rear mount turbo, 3psi running on meth having TM issues that I cant seem to improve. Running in speed density only, fueling is close. Ive bumped up peak torque 10% each dyno run and it seemed to help a little bit but now im not getting anywhere with it. Increased Driver Demand tables with no luck and increased Torque Tables with no change. TM is consistently kicking in the 5800 rpm and also in the 3500-3800 rpm range. First gen5 ive done so not very familiar with them, ive done a lot of reading and research on them about dealing with the TM but they are not working for me here on this one.
