Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: LS3 & GM performance trans controler
    2,971
    It does though.. and it worked much better (for me anyway) than the software the trans controller comes with.
    It didn't brick it.
    Tuner at PCMofnc.com
    It didn't brick it.
    Hmmm I have a junk 2010+ valve body here and the correct hardware and software to flash it with the GM cal. Maybe I'll give it a try.
    Good info there.
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
    Jun 2018
    Franklin NC
    35
    I must be doing something wrong. It want let me change the file to different type when saving file so could upload.
    Jun 2018
    Franklin NC
    35
    Quote Originally Posted by radrace19 View Post
    The TCM software will display the calculated speed. Are you using the USB cable for the TCM and the Chevrolet Performance software? Post the Chevrolet Performance .CPM file and I'll take a look.
    I am using usb to tcm using gm performance software.
    Tried and must be doing something wrong. Cant seem figure out how change file type to upload.
    7,989
    Add .hpt to the end of the filename.
  6. #26
    1,576
    Quote Originally Posted by 06TrailblazerSS View Post
    And don't do it while trying to do a save or save as. Do it on a Windows File Explorer rename.
  7. #27
    Jun 2018
    Franklin NC
    35
    CJ7.hpt
    Maybe?
    Have be changed back to cpm to open?
  8. #28
    That file is set to read the speed from the ECM via CANBUS, which are how the newer versions are set up. I forgot that changed a while ago.
    So, I think your issue has to be in the ECM programming like we suspected.
    I've attached a stock LS3 Chevrolet Performance calibration for you to compare to, but Chevrolet Performance uses E67 modules and not the E38 you are most likely using.
    Attachment 130257
    -Greg
    Edit: I was mistaken. The TCM IS using a calculated wheel speed. The vehicle speed check box is the driveshaft RPM via CAN.
    It calculates the wheel speed based on rear gear ration that is entered and the driveshaft RPM (which it is receiving via CANbus message). I see you have a gear ratio entered so I'm not sure why it isn't calculating, UNLESS the ECM is not sending the driveshaft speed signal via CAN message.
    I can adjust your file to look for the vehicle speed from the ECM instead of calculating it, but I'm not sure if that will work either. Let me know if you want to try that and I'll modify your file and upload it.
  9. #29
    Jun 2018
    Franklin NC
    35
    Attachment 130257
    -Greg
    Thanks I'll give it try
  10. #30
    See my edit above.
  11. #31
    Jun 2018
    Franklin NC
    35
    Attachment 130257
    -Greg
    Sure thing.
  12. #32
    Sure thing.
    Let me know if this file fixes it. (change .hpt to .cpm)
    Attachment 130258
  13. #33
    Jun 2018
    Franklin NC
    35
    Attachment 130258
    Changed back to .CPM
    Get error "This file does not match the correct format foor use with this software" when try opening the file with trans software.
  14. #34
    OK, I'm getting the same error. Let me see if I can work around the GM software limitation.
  15. #35
    OK, try this one.
    CANv3.hpt
  16. #36
    Jun 2018
    Franklin NC
    35
    OK, try this one.
    CANv3.hpt
    It did allow me open and write file. Still same no speedo.
    Guy from novak finally called back. Told me call GM performance. Thinks the controller only work for E67 & E92 controlers.
  17. #37
    Hmmm, that shouldn't be the case since the E38 and E67 should be the same as far as the GMLAN messages go, but give GM a call. Them might not be able to help since you are not doing something in their norms.
    -Greg
