Results 1 to 15 of 15
Thread: Oxygen sensors fitted grayed out in tune 13 mustang copperhead
    Mar 2023
    28
    I am trying to set the O@ fitted to 1 in my tune but its grayed out and can't change it. I want to run on bank 1 O2 sensor in Turbo DP, found all the info in the forums, but can't change my sensors fitted to 1. Is there something I'm missing somewhere?
    13,621
    Could be greyed out until you do the training course, that's just a guess. It's covered on the forum and on HP Tuners youtube channel for the newer software.
    SoCal
    1,631
    Yes you have to watch the video and take the test to unlock these settings.
    https://www.hptuners.com/emissions/
    Mar 2023
    28
    I did the test and added the code given in the training. Is there anything else needed ?
    SoCal
    1,631
    Nope. That's it
    Jun 2014
    11
    Mine are greyed out too and I?ve taken the training. I assumed this parameter was being locked now, but maybe I?m missing something. Post back if you get this to work.
    Mar 2023
    28
    No, they have it greyed out in all the 5.0 software. Doesn’t even show up in the beta version. I think I’m older software it is changeable. I got email back from support saying it’s greyed out because they don’t want you to eliminate it.
    13,621
    Guess you'll have to run both sensors or get someone to edit it for you.
    Yay EPA.
    Mar 2023
    28
    I went in and have both banks running on bank 1 sensor 1, turned off heaters to bank 2 sensor 1 and both rear sensors are disabled. It starts and stays in closed loop. Have something going on I’m trying to dial in , Stft were way off at first , as I was trying to dial in the MAF curve. At first thought injector data was off but verified correct for ID1050x with return style fuel. Set transport delay to 2x original in the 600-1200 ranges , lambda numbers seem to be tracking pretty good. Had to scale up the MAF quite a bit to get the fuel trims to be about +- 4-5% which doesn’t make since. Anyway I got a lot of tuning left to do. I’m pretty new to tuning with stock ecm but figuring it out slowly.
    SoCal
    1,631
    What was your reasoning for disabling the precat heaters? I would not have done that.
    Mar 2023
    28
    Only turned of bank 2 sensor 1 heater because it’s not in use or even on car.
    Mar 2022
    has anyone figured this out o2 sensor fitted is still grayed out. trying to rum 1 o2 but cant change it. ive done the course and code unlocked everything else but the o2 sensor
    Oct 2016
    Poland
    1,776
    This wont be available anymore - EPA. Even if you do the course.
    But since we dont care about EPA here in EU you can email me directly...
    Sep 2022
    Clearwater FL
    219
    Pretty sure I still have access to this. Which exact table are you referring to
    May 2019
    17
    Quote Originally Posted by Radialoutlaw View Post
    There is a way. First you have to have a comparison file that has the number of o2s that you want. If you don?t have one I can help you with that also. Next go to compare, view comparison log, sensors fitted, right click, copy over selected difference. It will change to whatever was in the comparison file. This works on almost any grayed out
