Results 1 to 9 of 9
Thread: (pe eq ratio gas) vs (pe eq ratio alcohol)
    Sep 2007
    patton, pa
    160
    at what percentage alcohol does it switch to the alcohol pe table? or doesn't it work that way?
    2010 silverado 6.2 ,Doug Thorley try-y headers, cats deleted ,spectra air cold air, lifted with 33's,tsp vvt 1.2 cam hp tuners
    Tuning Addict
    6,873
    Depends on what you have in the multiplier table and how everything else is setup.
    ~Greg Huggins~
    Aug 2021
    557
    Quote Originally Posted by davez28 View Post
    Check the "[ECM] 12636 - PE/COT Spark Advance Correction Mult vs. Fuel Composition" table. Here is how I have mine set up. Basically nothing happens until 10%+ then it interpolates up to the 20% cell.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Feb 2018
    844
    So that table not only adds spark but also switches to the eq ratio (alcohol) table?
    Aug 2021
    557
    Quote Originally Posted by sgod1100 View Post
    Sorry my bad...that table only effects spark. As far as I know the PE should always be interpolated based on alcohol % (0-100%) between the [ECM] 12400 and [ECM] 12403 tables.
    If the tables are the same, then nothing will change with E during PE. Are you specifically seeing something off in your logs?
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Feb 2018
    844
    Nope, not at all. I've never ran E through my car (yet). I was just confused as to if that flex fuel spark table was doing more than I thought.
    Aug 2021
    557
    Peep this: https://forum.hptuners.com/showthrea...l=1#post712615
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Feb 2018
    844
    will do, thanks!
