Results 1 to 15 of 15
Thread: 2022 gt shutting down and going nuts
    Dec 2018
    11
    try to make a good pull in 6th gear (10r80) around 120-125mph it shuts down. it actually goes nuts. throws every warning on cluster that it has plus wrench light. touch the throttle afr's go dead lean. pull over shut it off for a minute or 2. start it back and everything is good. im stumped. any help would be appreciated. i very seldom hit those speeds but its very aggravating not being able to figure out the problem. runs and drives great on my e85 tune but at 120-125mph game over.
    Mar 2018
    447
    Call the guy who tuned it.
    Dec 2018
    11
    Quote Originally Posted by K44 View Post
    i tuned it. i'm overlooking a limit somewhere apparently.
    Dec 2017
    767
    Post log and tune so it can be reviewed
    Mar 2022
    9
    Try going to TRANSMISSION > General > Limits > Element RPM Limit. Max that table out and try it. Also, you might have to raise the Planatary, Ring Gear, Sun Gear, and Carrier Gear limits also. I have had that issue once and if I remember correctly that was my issue.
    Sep 2022
    Clearwater FL
    215
    It's probably your torque limit. I forget the exact torque table I'm thinking of but I had to change mine because I would have this issue often
    Dec 2018
    11
    Quote Originally Posted by TWSUPERDUTY View Post
    thanks for the reply. i had previously adjusted everything you mentioned except the Element RPM limit. i haven't had a chance to give it go yet but i appreciate the help
    Dec 2018
    11
    Quote Originally Posted by Pistol_91 View Post
    i've raised all torque limits but will check again. thanks for the reply
    Mar 2022
    9
    Let me know if that fixes the issue. If not I will look into a few more things that I changed by doing a file comparison to the stock file. But I did have the same issue for seemed like forever. Looked and looked over the tune night after night and trial after trial lol
    Mar 2022
    9
    Also, I seen you had e85 tune. Do you have any problems with the throttle closing on top end say around 6600 rpm or more like closing down to 50-60 %? I do and just been trying to figure out how to keep it from closing. It runs great other then that. it shows torque source injector limit.
    Sep 2022
    Clearwater FL
    215
    Wheel Tq Error Max. Is this still stock?
    Mar 2018
    447
    If none of the above fix it post your tune with a log. If you do that many here can help, without we all are guessing.
    Dec 2018
    11
    appreciate the help. i raised it and element RPM limit as another member suggested and its good now. so one of the 2 or both done the trick. thanks abunch.
    Dec 2018
    11
    i'm dedicated E85 tune not flex. dedicated E is alot easier to do than flex tune. i wish i could help you but never messed with flex tables. sorry. i raised element RPM limit that you suggested and wheel torque limit that was suggested by another member and it fixed my problem. one of the 2 or both fixed my shutting down problem. thanks for the help and i wish i could help with your injector limit problem but i have no idea. you could try a dedicated E tune which is really simple from a test standpoint and see if your getting the same error.
    Sep 2022
    Clearwater FL
    215
    Quote Originally Posted by robg View Post
    From what i understand increasing the Wheel TQ Error Max is just a quick fix. Im not sure what you set yours to but mine is at 120k and havent had it go into limp mode since i changed it... Max input value is 1,000,000. I probably wouldnt set it to that. As for the element RPM limit you mentioned ive never changed mine before so i dont think that would throw it into limp mode
