Thread: 2022 5.7 RAM Downshifting on Dyno
    Anyone help with getting this ram to stop DSing? have tried 3rd gear and shifts to 2nd and tried 4th and shifts 3rd. Have pull ABS sensor, set displacement to 0 and still does it. IT says it uses table 27 in M mode so I tried raising DS tables to something it wouldn't get to like 6600rpm and it made things worse. Tried TRX tables as well. TIA.
    Unlocked ECU OG.hpt
    2008 Corvette
    UPP Twin turbo T4 67mm BB billet wheel kit
    427 LME Billet Setup
    Fore Innovations Triple 465 L4 Setup
    FIC 2150 injectors
    RPM TH400/9 inch
    Pro Torque Bolt Together Converter
    MaxxECU Stand Alone
    *UPDATE* Was still down shifting at the end and didn't see. Ended upgoing one by one setting back to stock until I found the one affecting. Manual mode and normal driving share the same damn tables so I don't see a way of racing this truck in M mode cause normal mode will NEVER DS." TY Spool boy worked perfectly. I guess I was going the wrong way with the downshifts. Can we make these trucks not down shift in manual mode only? I want to be able make hits in manual mode but also let it down shift in normal mode. I wish scanner would give me the damn shift pattern its in for this truck.
    2008 Corvette
    FIC 2150 injectors
    RPM TH400/9 inch
    MaxxECU Stand Alone
    Yeah that's my issue it wont pull up shift ID on this truck. It did on the 22 TRX I did. ITs just button plus and minus on the front of steering wheel.
    2008 Corvette
    FIC 2150 injectors
    RPM TH400/9 inch
    MaxxECU Stand Alone
    Jan 2022
    972
    Quote Originally Posted by JekylHyde View Post
    post a log
    you mean upshifting?
