Results 1 to 14 of 14
Thread: Possible to see Lambda target and actual lambda in vcm scanner?
    Apr 2023
    17
    Stock LT4, is it possible to take a log and then see Lambda target and actual lambda in vcm scanner?
    I think I got one ok, I set it to EQ Cmd (λ) and can see data.
    But how to see the actual lambda?
    Aug 2016
    386
    You don't, unless your vehicle has WBO2s. Unless it's a CT5 Blackwing or Escalade-V, it doesn't have WBO2s.
    Apr 2023
    17
    It is a cts-v, guess I have to install a wideband then..
    Any prefered WBO2s?
    How do you tune without seeing the actual lambda?
    Aug 2020
    Petersham, MA
    134
    Quote Originally Posted by etxridn View Post
    Any prefered WBO2s?
    Use the AEM 30-0334. It communicates through the cars canbus and you can read wideband data through HP Tuners.
    2017 Camaro SS, Whipple 3.0, Mast LT Black Label heads, 112mm TB, LPE BB HPFP & LT4+52% injectors, Fore Innovations triple pumps
    1059 WHP, 944 WTQ
    Tuner in Training Clutch's Avatar
    Mar 2019
    SW,Florida
    47
    Make sure it's calibrated in the scanner; IE: Make sure what you see on the wideband gauge matches what you see in the scanner. Otherwise, you'll be chasing your tail.
    1997 C5 - 346ci - M6 - custom CAI, ported TB, MAF (ported & descreened), 1-7/8" Lt's, 3"X-pipe, modified stock muffs, 345rwhp before headers/x-pipe
    Apr 2023
    17
    Thank's. How do you tune without seeing the actual lambda, i guess everybody doesn't install wbo2.
    7,978
    LTFT+STFT error. That only works for the closed loop regions though. Need a WB to get everything done, without it you're only guessing and the open loop parts are where the engine is making enough power to actually hurt itself.
    Apr 2023
    17
    Yes, it is in the open loop i am wondering how all tuners are tuning just based on logs without wbo2?
    7,978
    When you figure out how to tune the open loop/PE without a wideband, go file a patent for that shit. You'll be rich and famous and revolutionize the world of tuning.
    Apr 2023
    17
    Haha, ok.
    I guess some hint would be the voltage of the o2 sensors?
    7,978
    Narrowbands are not linear, the voltage can only be used to tell stoich, richer than stoich (over 450mV), or leaner than stoich (less than 450mV). That's why all these systems go open loop and ignore the narrowbands in PE. Because they stop giving usable data anywhere except right at stoich.
    or LNF, they have factory installed wb too!
    Mar 2019
    SW,Florida
    47
    LOL!
    Aug 2016
    386
    Quote Originally Posted by fst100 View Post
    OP said LT4 without specifying vehicle type, so I only included the LT4 based vehicles that are known to have WBO2s.
