Results 1 to 6 of 6
Thread: 2020 jeep magnuson throttle oscillation and throttle WOT delay
    Jun 2010
    293
    throttle body start to oscillate when map goes 1-2 psi of boost at part throttle. also it takes some time until throttle body goes full open.
    any help? thanks
    Jan 2022
    972
    its not just slow to wot...
    looks like it should be open more than it is for the voltage it is seeing
    most of the airflow tables look stock
    i have a bunch of ideas but no experience : )
    magnuson comes with its own tb yeah?
    Jun 2010
    293
    it uses the stock throttle body. yes i did turn back to stock almost all throttle tables and driver demand tables because was testing the throttle oscilation and the WOT body lag without any succes. attached is provided magnuson file
    Jan 2022
    972
    yeah i dunno. you put a super charger on a engine that has 4 cams, variable valve timing, and variable LIFT as well
    you have the stock file?
    Feb 2016
    431
    Airflow tables, throttle tables and cam timing (and a heap of other small things) need work with a blown pentastar.
    Use this tune as a guide as to what needs changes and what doesn't.
    Jan 2022
    972
    there ya go.
    that will not just lock the ex cams, but it will bring em forward almost 50 degrees before it does , )
