Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 110
Thread: stumbles on cold start
  1. #41
    Tuner K Rob's Avatar
    Apr 2021
    Oklahoma City, OK
    88
    Would not start or idle without using the pedal
  2. #42
    Mar 2022
    Indiana
    3,072
    Man what the hell. If this doesn't show improvement I don't know what else to do.
    - Cranking VE
    - VE
    - Fuel>Open Loop/Base STFT Open Loop Enabled
  3. #43
    Apr 2021
    Oklahoma City, OK
    88
    Gm and let’s hope so !!!!
  4. #44
    565
    Start up try.hpt
    Give that a try and see what it does. I'm curious for a better, same or worse
  5. #45
    Mar 2022
    Indiana
    3,072
    Quote Originally Posted by reubone View Post
    Start up try.hpt
    MAF is disabled for this SD portion. You're going for a MAF tune with this. Maybe you directed the changes to OP's first tune, but MAF fail is still 0hz, so the MAF settings won't work until that's changed back.
    Cranking VE maybe, but I doubt it. Car is rich already.
    I like your idea on min fuel in the Transient tab.
  6. #46
    Indiana
    331
    If its running rich (im just coming in on the last page of this) why not try lowering the BRAF? its pretty high and for a cam that size id think itd be less since the VE table is so low at idle. i know its significantly higher than my BRAF on my cammed 5.3 thats 60-65% efficient in that area vs your 30%...Maybe my thought process is wrong here but lowering BRAF back down would cause less fueling due to less air, same effect as lowering % in VE table.
    IAC steps start out pretty high as well...
    Also, in transient fueling, it looks like fuel to wall impact factor has been lowered and i wouldve expected it to be raised in areas to account for the larger injectors. boiling time hasnt been touched and that should be raised in the low map areas to compensate for lower VE and ability to evaporate the leftover fuel.
    Nothing has been done with injection timing either. On a cam that size the EOIT should be pushed back farther until the exhaust valve is closed or closer to it because of the excessive overlap. this Helps with not losing raw fuel out the exhaust but again changes transients because its spraying on an open intake valve, so you lose the cooling effect of spraying the back of a hot, closed, intake valve, thus the fuel doesnt atomize as well and again you get more transient fuel puddles.
    Is injector data correct?
    Just some suggestions....
    Heres an EOIT chart to illustrate what im talking about with injector timing. Also Spray pattern and angle has alot to do with transients when you go from one to another.
  7. #47
    Apr 2021
    Oklahoma City, OK
    88
    Update log - could there be a mechanical issue causing this ?
  8. #48
    Apr 2021
    Oklahoma City, OK
    88
    Quote Originally Posted by horsepowerguru427 View Post
    Thank You for your suggestions !!!!
  9. #49
    Indiana
    331
    your power enrichment was set to be on all the time. i fixed that and also disabled DFCO which you had enabled all the time as well. i adjusted transients and eoit a little as well. The PE alone was putting you at .8 lambda plus OL fuel table is pretty close to what EQ ratio it was commanding in the log. try this tune file and see if it helps any....If it was mine id wanna start fresh so i knew what all was changed, but thats me.
  10. #50
    Apr 2021
    Oklahoma City, OK
    88
    I opened up the throttle blade just a bit and reset the tps - its blowing raw fuel out the exhaust as it has been - Thank You all !!!
  11. #51
    Apr 2021
    Oklahoma City, OK
    88
    Okay it fired right up - high on idle speed - I took 1 turn out to bring down idle some
  12. #52
    565
    Excellent catch. I didn't even look there as the ve was only set to disable after 3500 rom previously so I figured it was enabled. My bad
  13. #53
    565
    Start up try again2.hpt
    Hopefully between all of us we will get there
  14. #54
    Apr 2021
    Oklahoma City, OK
    88
    okay - i opened it up 1/2 turn to get it to start and closed it 1/4 after startup
  15. #55
  16. #56
    Apr 2021
    Oklahoma City, OK
    88
    No start
  17. #57
    Mar 2022
    Indiana
    3,072
    Wait lol. The PE was on the whole time? No wonder. Thx horsepowerguru427.
    K Rob which revision are you using? Like are we trying to do SD, or did you switch it back to MAF tuning? From now on it'd be helpful to post the tune you used along with the log. It's hard to keep track of all the revisions otherwise. VE12 looked a lot better, but what changed? Was it PE settngs or enabling MAF or...?
  18. #58
    Apr 2021
    Oklahoma City, OK
    88
    Startuptryagain.hot goes with ve12
  19. #59
    Mar 2022
    Indiana
    3,072
    Ok then it's still in SD mode. MAF fail is still 0hz.
    Is the fuel system factory? It seems like maybe high pressure.
    Lowering VE is showing improvement, but it's getting down into pretty low numbers to make it work right.
  20. #60
    Apr 2021
    Oklahoma City, OK
    88
    Stock short block LS1
    TEA light ported Trick
    Flow 220s
    64cc chamber (10.5:1)
    BTR stage IV cam
    233/248 .630/.615
    111.5+2.5
    92mm intake and throttle body
    E85 42Ib iniectors and
    Racetronix 255 pump, with hotwire kit.
    Kooks 1 7/8 headers 3 inch collectors. 3 inch y pipe to 4 inch Mufflex exhaust Magnaflow muffler.
    Th400 reverse manual valve body. With trans brake.
