Results 1 to 7 of 7
Thread: Virtual Volumetric error - incomplete zones warning
    May 2023
    23
    xxxxxx
    Tuning Addict
    7,184
    Normally gives this warning if you're tuning something with boosted zones in a non boosted format. Didn't do this years ago, but the newer editor versions do... Click on the map axis and change it to the middle option and tune it on that setting. Otherwise if it's not boosted - which looks like from your name it is - you'll need to change your zone settings to be able to make corrections in the 1 bar format.
    ~Greg Huggins~
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,171
    Quote Originally Posted by CTSVNZ View Post
    VVE creates a warning error every time I try and make a change.
    Warning is that I have incomplete zones - and I do.
    As in the factory numbers do have zones 17,23,and29 missing.
    If I open the page, click 'show zone numbers' indeed 17,23 and 29 are not listed.
    If I make even one change on this page - like change one number only - and then press Virtual VE - Coefficients, I get the warning 'incomplete zones' 17,23,29 etc.
    So ignore it?
    It seems each cell is updated corrected (when pasting in % from the scanner), but warnings worry me.
    Thoughts please
    screenshots attached
    Attachment 132644
    Attachment 132646
    Attachment 132647
    Looks like your MAP axis only goes up to 105 kpa. This is cutting off the bottom zones. You need to edit the row definition to include over 105 kpa (boost area).
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    May 2023
    23
    xxxxxx
    May 2023
    23
    xxxxxx
    Feb 2018
    950
    Interesting to view - actually I have Maff turned off for VVE tuning. It is kinda lazy rather than off off. Not sure when off it should stop loggiing any numbers? For off I used MAF Frequency Fail High - 1 Hz (was 14,599Hz) and MAF Frequency Fail Low - 0 Hz (was 1,126Hz)
    Thank You
    check this out. This thread was created by Cringer and I have been using his equations to tweak my maf and VVE with good results. Best thing is no need to disable maf and/or VVE to tune the other.
    https://forum.hptuners.com/showthrea...-the-Same-Time
