I just swapped out my 5.3 for a 6.0 with a 232/236 112+2 cam and L92 heads with l76 intake and 90 mm TB.
I'm having a hard time getting it to start and idle. It will only start if I give it some throttle and it only idles when it wants to. Sometimes it will idle for a minute and then stall and some times it won't idle at all. I can't put it in gear with out two footing it. Here is the current tune and a log file using Russ's Idle config. Any help would be appreciated TIA
