Hello all I have a 2009 6.0 from a g8 as a swap in hotrod, i do entire flash with vats disable and start dia disabled with all dtc turned off. i get cam counts and rpm counts, motor runs with spray, but i have not injectors firing, on a snap on scanner i see that fuel VTD is yes? tried many times flashing no fire.... Im attaching files not sure if this helps. i'm at a wall . thanks john truck tune 2a.hpt23-06-20 21-01-56.hpl
