Results 1 to 5 of 5
Thread: AEM 30-0334 to MPVI 3 connection issue
    Jun 2023
    4
    Helpless new guy who has read endless threads and watched all videos I could find.
    MED 17.1 2010 GTI. MPVI 3 connected bypass through the AEM OBD pass-though (nothing else connected to OBD.
    Changed to all 7 channels on the AEM gauge, with no success in having it show up on the OBD controller list.
    Please see the attached screen shot as a reference, let me know if additional data is necessary, I have no idea what is ok to share, and what's not.
    For each of the 7 channels the ECM:7E8 and it's following information is unchanged, I believe that is to be expected.
    Below where it says NONE:7EE, below is the read out for the 7 channels in the AEM gauge:
    NONE:7EA
    NONE:7EB
    NONE:7EC
    NONE:7ED
    NONE:7EE (Channel 4, according to my reading, this was supposed to work)
    NONE:7EF
    TCM:7E9 (this was channel 1)
    I repolled parameters after each change, checked the channel, and attempted to connect the gauge via OBD controller, not the external inputs. No luck.
    I'm lost and need help, any insight would be greatly appreciated.
    Jun 2023
    4
    Ticket 105694 opened.
    Apr 2024
    Any update? I'm having the same issue
    Jun 2023
    14
    Same, so I wired the gauge to the analog pins ( black/brown pin10, and blue Green to pin 9) using the pro link and I can see it when I connect to the car but as soon as you start logging it disappears.
    Sep 2023
    25
    Any luck on this? I thought it was just me trying to use the new Can-Am adapter and MPVi3 but same issue.
