Results 1 to 18 of 18
Thread: Injector Duty cycle
    Apr 2023
    45
    Injector Duty cycle
    have a 1988 Fiero GT with a swapped stock L32. I noticed that my injector duty cycle under WOT was getting up to 99% and I couldn't find any info, or get any answers to why a stock engine would be running out of injector.
    I decided to change the injectors and put in a set of 42# injectors and changed the fueling to get it back to 14.7. I took it for a good run and it seems to run ok, but when I got back and looked at the data it's now saying my injector duty cycle is at 119% at WOT.
    How can that even be possible?
    Mar 2022
    Indiana
    3,081
    Good question. Let's see the tune.
    Apr 2023
    45
    Here it is.
    13,615
    Why are you asking for so much fuel?
    You have the BASE commanded AFR at 11.8 but then you also are adding in fuel from the RPM adder. There are times where you could be asking for 9.0 to 10.0 AFR.
    Zero out the RPM adder table if you only want to command 11.8 AFR in power enrichment. Then retune the MAF curve to get your fueling on point.
    Apr 2023
    45
    Newbie question, couldn't that cause not enough fuel under boost?
    Mar 2022
    Indiana
    3,081
    That setup is for supercharged like the GTP.
    Regardless, DC should still be a lot lower, especially given flow rate.
    I wonder if it's your channel settings? For Injector Pulse width and RPM you're using the general sensor right, not the engine-specific? Sometimes the specific does weird things.
    Math for IDC: IDC = IPW/(1000/(RPM/120))
    https://forum.hptuners.com/showthrea...inj-duty-cycle
    Apr 2023
    45
    L32 is supercharged. Series 3 with Series 5 blower.
    Mar 2021
    Pompano Beach FL
    272
    Did you check fuel pressure?
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Apr 2023
    45
    Quote Originally Posted by N2speed View Post
    Yes, fuel pressure is set to ~50 and rising with boost. I also recently upgraded to a 340 LPH pump to make sure it had all the fuel it wanted.
    Apr 2023
    45
    Well, I still don't know why the stock injectors were maxing out on a stock engine, but I did finally find out why it was even worse with the 40# injectors. I sent the numbers off to Witch Hunter and found out that Kenne Bell fucked me over selling these with a chip as 42# injectors when they are actually only crap 28# injectors. All the years of money and frustration with these injectors to find out it was all a scam.
    Back to starting board yet again.
    Thanks for everyone's help.
    SoCal
    1,624
    Got to thank blindsquirrel for this. Put them on almost everything now.
    https://www.ebay.com/itm/274424906026
    Mar 2022
    Indiana
    3,081
    Needs adapters. I hate adapters. Fire hazard to me, but not to some.
    https://zzperformance.com/collections/3800/fueling
    Green Giant or Deka 60. They're on ebay, too. Data exists.
    Apr 2023
    45
    $55 for 8, and they actually work? Most sets of 6 I've seen are over $300
    Mar 2022
    Indiana
    3,081
    Probably. Listing says new (other) and there have been hundreds of sets sold by that seller. If you go with these don't forget your adapters and pigtails.
    Apr 2023
    45
    I put in an order for these, now I wait to see.
    Apr 2023
    45
    Thank you everyone for your help.
    SoCal
    1,624
    I have installed no less than 20 sets of these since blindsquirrel turned me on to these. I have recommended them to many people and not one single bad word from any., They are brand new not rebuilt. E85 injectors with GREAT data.
