Support for Nissan y61 does it work on
HP Tuners MPVI2
HP Tuners MPVI2
the OBD in most models does not support CAN
Remote Tuning [email protected]
Y61 is currently in the final testing phase.
Any news on the Y61? I have a serious client whose 2009 Patrols run in international rallies with piggy-back ECUs. He is about to spend $1800/car on plug and play ECUs but if we can tune his factory ECU...
Could you gives us a hint on the time frame. And what we would be able to tune?
Can I bump this? Y61s are not afraid of bumps The race team with 3 Patrols did not order the Haltechs yet. Maybe we can HPTuner them after all
No news on Y61? It is finally coming down to the wire. They have to decide in a day or two and the Haltechs will run them about $1800 each all installed.... I really wish that HPTuners had been able to be their answer.
Thanks for letting us know. The race team has one 2017. Maybe they will go that route with it. Their 3 2009s are the main need.
i believe CAN for the Y61 was available around 2015+ from what i have seen.
What features does HPTuners have for this engine over other flash options like UpRev? I suspect it may be possible to retrofit the later CAN ECU for manual transmission models where the K-Line is only for diagnostics and not for TCU or cluster communication. Is there an example hpt file I could look at to compare tuning interfaces?
Can the Zd30 ECU be tuned on a Y61 Patrol 2010 ?
