Hello
I noticed car from start is driving timing i have not seen in any table i have, takes around 30 sec to one min until it switch to timing is set in tables.
That causes some bogging in supercharger car when cold with low load and that low timing. Attached log from hot start and driving with constant speed and map, at around 1500 rpm, you can notice at one point it switched timing from 14-15 degrees to 25 degrees. Anybody experienced that?
04. from start table switching.hpl
