Results 1 to 2 of 2
Thread: 07 expedition strange file data
    Apr 2023
    11
    I recently read the TCM file on my 07 expedition with a 6r80 and the read data seems odd. This vehicle originally had a 6r75, but i have since swapped that for the 6r80, and thats a story for another time. The tables and graphs just dont seem to make sense to me, like the data seems strange. I have access to an 08 6r80 i could read and compare with. When looking through the trans tabs on editor they are really slow to load, the other engine related tabs load just fine. Thinking there was an issue with the read. Can someone take a glance at the trans side of the file and tell me if its messed up or not? thanks.
    Tuner Lost0187's Avatar
    Oct 2021
    Canton Ga
    156
    There are some differences with the 2007-2008 6R75 strategy but that shouldn't stop you from controlling the 6R80 if you need any help I can lend a hand. The 6R75 used OD off 5th locked logic while the 6r80 has a T/H logic built into its strategy. Some tables will be different but they all mostly control the same things.
    King Ranch Expedition 5.4 3v 6R80 Coyote PCM , M112 Blower, Kooks Long Tube Headers, Green Cats, Aeromotive Regulated Return Fuel System, ID 1000 Injectors, Custom Interior Wiring, Track Apps, EPS mode adjustable, +6 Blower Pulley w/ Innovators West SFI Balancer, Afco Dual Fan ZL1 Heat Exchanger, Flex Fuel E85 0-60 5 secs 12.0 best quarter mile time.
