Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: 12 F150 Not Making Much Boost at WOT and BOV Acting Crazy Part Throttle
    565
    I noticed this today. This is what your high LSPI table looks like and it should try to follow this.
    However, It is following exactly what the stock setting were not what is in there now. Check this out
    Do you guys know why this is happening? Should we have to perform a write entire to make this change work?
    Jun 2019
    Wisconsin
    316
    Shouldn't have to, but it's an easy thing to test out.
    565
    Any Updates on this?
    565
    Max torque WOT was probably the reason
    tune 14 try.hpt
    Jan 2022
    34
    Quote Originally Posted by reubone View Post
    Sorry about the delayed response to get back, holidays got crazy so I haven't been able to get much done as of late. It's my buddies truck so I had to give it back to him. The last revision that went in with I believe try 12 and he hasn't said anything about it since so we called it at that. I can try to get the truck back again to try the other things you had messed with but it may be a bit before its able to be back in my hands
  6. #26
    565
    Sounds good no worries. Keep us posted if you can. We like learning haha
  7. #27
    Mar 2023
    40
    I see have some KR to.
  8. #28
    Mar 2023
    40
    I looked at your VCM scanner files, I see you lose all intake inlet pressure to you turbos and wastegate duty is zero too or BOV BAD. That's problem with wastegate opening to soon. Also you have KR running to much timing, you can use your VCM Scanner file copy retard graft and paste it by percentage 1/2.
  9. #29
    Mar 2023
    40
    tuning
    Hey I tuned your file for you, need to run VCM Scanner and check the KR and let me see the VCM file to make some changes to fuel and timing.
  10. #30
    Mar 2023
    40
    tuning
    I tuned a file for you. But you have a problem either with your BOV or wastegate.
  11. #31
    Mar 2023
    40
    up dated tune
    This tune had limiters still and I removed popcorn and more, did nothing to the shift pattern or times. Just tune it more and should run better.
