Results 1 to 7 of 7
Thread: 6.0 Powerstroke Tuning guide
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    490
    This guide was made by me. It might not be the way YOU do things but I have had success with it. This is a beginner guide for people who are just starting out and need to know what, when, why and how. I am sure as time goes on this guide will change and I will be doings some individual guides on certain things to clarify some tables/items.
    Thank you!
    https://docs.google.com/document/d/1...it?usp=sharing
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Banned
    Jan 2020
    Arlington WA
    247
    5TH Gear is 1:1 ratio..not 3rd.
    Jun 2012
    warrenton va
    490
    Quote Originally Posted by Powerstrokecustoms View Post
    Thanks! i changed it in the guide. should be updated shortly
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Nov 2022
    5
    Is there a way to turn off the egr valve?
    Jun 2012
    warrenton va
    490
    Should be able to unplug it.
    But I can make XDF?s to control the EGR valve
    Sep 2024
    Appreciate you, very good write up and info. Helped tremendously with my 6.0 tuning. Just have to fine tune a little more but it feels very responsive and rewarding.
    May 2024
    7
    What is the importance of the Pedal Map and Pedal Map Copy being the exact same? Reason I ask, I pulled the tune from my truck and they do not match
