Any body got a good tune for a 2019 Polaris ranger 1000xp
Unfortunately, anyone that does have a custom tune written by a tuner will likely have their tune read locked. Unlike the automotive world where people share everything... The powersports world is very different.
Do you know of any things to adjust to get more power and I?m trying to disable the brake to start
Mind posting the factory file off of it?
What you mean by factory file
the stock read you got off it
I have started playing with the Polaris XP1000 platform. The cool thing about a cvt transmission is you bascially have a dyno built in. Watch you shift out rpm and if your changes make more power you will see more rpm if you make less power you will see less rpm. There is alot of gains to be had on the Ranger with just throttle control.
I imagine there is a ton of power pulled out in the early RPM range to save on belt life? Ramp in the power quicker probably makes it a hoot better to drive!
2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
2010 GMC Sierra LMM Duramax. Exhaust and tuned
