Page 6 of 6 FirstFirst ... 23456
Results 101 to 108 of 108
Thread: Dodge Viper Gen3 (JTEC/JTEC+) and Gen4 (Venom) tuning
  1. #101
    Tuner 53mercury's Avatar
    Feb 2011
    Alberta, Canada
    96
    Hello folks
    Been messin with this swapped Viper powerplant (Gen4 2008 in a Roadrunner) that is standalone using all the components from the Viper. Tuned with HP Tuners but can?t seem to get it from going into limp mode. P2104 always sets no matter what I do. I?ve done the throttle relearn many times with a Chrysler and hp tuners. Only thing changed is the maf location. I?ve disabled air flow diagnostics and deleted the code but it changes nothing. Anyone with ideas?
  2. #102
    Mar 2020
    9
    Quote Originally Posted by 88nec View Post
    Hello everyone. I have a jeep wj 2004 4.7 pcm JTEC+. I turn off p0443 and p0136 p0158, the MIL lamp is off, but there are errors when reading with a scanner. What can be done about it?
    Having exact same issue with my 96 Ram 1500 5.9 pickup with a 5 speed swap. Turned off all auto controls and CEL is now off but still have a couple P07XX codes when reading with the scanner. Would also like some help. Any help appreciated.
  3. #103
    May 2022
    Denmark
    6
    Hello Friends
    Would it be possible to attende the beta program? Sent email to support over the weekend but no replay yet. Have also made this tread
    https://forum.hptuners.com/showthrea...0-1500-my-2006
    Thanks in avance
    Pierre
  4. #104
    May 2022
    Denmark
    6
    Hello anyone please
    Best Regards
    Pierre
  5. #105
    Jul 2020
    7
    Quote Originally Posted by 2001CamaroGuy View Post
    Any update on opening up the DTC table for the jtec ECU?
    bump for this. I have a 2006 Viper, customer did aftermarket exhaust and need to turn off codes for the rear o2 sensors. I went through and disabled them via HPT but the CEL is still coming on. Can anyone help with this?
  6. #106
    Aug 2009
    Calibrating
    3,390
    Quote Originally Posted by northpoletuner View Post
    Not possible on that model
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  7. #107
    Mar 2006
    7
    What is needed to read & flash a 2003 Viper? Listed as supported. I can't get anything to work. 2003 supercharged viper that was tuned 20 years ago locked with whatever PVO was using? Guy is begging.
  8. #108
    Mar 2006
    7
    [QUOTE=John B;738226]What is needed to read & flash a 2003 Viper? Listed as supported. I can't get anything to work. 2003 supercharged viper that was tuned 20 years ago locked with whatever PVO was using? Guy is begging.[/QUOT
    Found it!
