Results 1 to 11 of 11
Thread: No power at full throttle
    Jul 2023
    6
    So recently did an ls swap motor is completely stock with a 4l60e. Has new plugs, coil packs, plug wires, injectors, new maf sensor. Car has no codes whatsoever. It has 60psi of fuel pressure also. So my question is could it be the tune or would it be something else mechanically just needing some ideas because the car starts up fine and idles and revs in park really well. but when driving you go 100% throttle it downshift but there is just not a lot of power.
    Log file: juan drive 4.hpl
    Tune File:Juan 4th computer tune.hpt
    13,599
    Depending on the weight of the vehicle, the 4.8 doesn't make much power. You are probably at 220-230hp and similar torque from that smaller engine.
    I can't view the data log on my computer to see what the log looks like.
    Jul 2023
    6
    The car weighs around 3600lbs
    Tuner awest623's Avatar
    Oct 2019
    Pyeongtaek, South Korea
    70
    You definitely have a fueling problem, running stupid lean. In some spots it's adding up to 42% more fuel with fuel trims. The only places fueling looks normal is at idle and on decel. Nothing in particular sticks out to me in the tune assuming you have a 4.8, have you checked fuel pressure while driving? It should be around 60 key-on-engine-off, drop down to about 50 at idle, and rise back up to 60 at full throttle.
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * AUS 43lb injectors
    * Comp 08-410-8 with 1.6 rockers
    * P59 swap
    * Whipple supercharger
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    * Cal-Trac traction bars
    * 1" blocks, 265/70r17 BF Goodrich KO2s, 17X8.5 ALPHAEQUIPT COMMAND LT
    Oct 2019
    70
    If that checks out. Can I see a log including injector duty cycle?
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    Jul 2023
    6
    What would that be located under?
    7,899
    Injector Pulse Width Avg. Bank 1
    Injector Pulse Width Avg. Bank 2
    Jul 2023
    6
    So fuel pressure seems to be good. But i pulled the plugs and 1,3,4,8 look lean and 2,5,6,7 look really rich could it just be i got bad injectors?
    Injector Duty Cycle log:Duty cycle.hpl
    Oct 2019
    70
    Duty cycle seems fine. Bank 2 is richer than bank 1, but both are still very lean.
    You mentioned you got new injectors. Do you have the specs for those? Or a link to the website you bought them from?
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    2,922
    It needs tuning.
    Its pretty lean driving and looks very rich at wide open throttle.
    Tuner at PCMofnc.com
    565
    The way your map sensor is fluctuating, I think you have mechanical problems that need ironing out.
