Thread: Would HPTuners allow me to do what I want?
    Jul 2023
    I have a 2016 Challenger SXT.
    1) The throttle delay/lag seriously irritates me, and I want to reduce it.
    2) My transmission has a fault and is a bit rough downshifting from 3-2, but only if I leave it in full auto and let it downshift at 6mph. If I select 2nd at 15mph, it's smooth. Can I use HPTuners to change the 2-3-2 shift points, without changing every other shift point too?
    And I see that for the upgrade service, I have to include an HPT file if I'll be using a donor PCM. How do I get that? Do I buy the tool first and then scan to obtain the HPT file?
    Thanks.
    28,312
    Quote Originally Posted by elseif View Post
    Yes.
    You read your stock ecm using your MPVI device so that we can essentially clone your stock ecm.
    Jul 2023
    Thanks for your help!
    And does the "yes" apply to my first concern, would I be able to reduce the throttle delay too?
    I realized after I posted that I didn't clearly state it as a question.
    Also I saw that the PCM seller asks for my mileage. What if I drive my car between now and when I receive the PCM, will I be able to enter the correct mileage into the PCM via HPTuners to avoid throwing an error / etc.?
    Tuner in Training DobermanRacing's Avatar
    Jul 2023
    14
    I only have experience with GM Gen 5 tuning but it will allow you to change the throttle commanded vs actual response so if you're vehicle is dbw I don't see why you wouldn't be able to adjust it.
    For the mileage you can not change it through hp tuners. Again not familiar with your vehicle but some store the mileage display in the cluster itself in which case you'll be fine. If it's in the pcm your mileage will be off.
    You may be able to pay a dealer to flash the correct mileage but your mileage may vary (pun intended) with that.
