Results 1 to 7 of 7
Thread: Rtd tunes
    May 2023
    Rtd tunes
    I?m new to this and I have a rtd device and probably a locked tune. If I get a mpvi3 will I be able to see what has been done if I download the tune from my car. Im not looking to change or do anything other than see/know what has been enabled/disabled or what set points are for things like o2, misfire, afr etc.
    Purely for my own knowledge and maybe piece of mind.
    Quote Originally Posted by Newtuna View Post
    Negative ghost rider, the lock is there on all HPT devices
    Compare the OS #on the RTD file to your stock os#. If they are the same you can read it out on a MPVI. It is common for tuners to scramble the OS so it cannot be read. I have successfully done it once.
    Feb 2016
    486
    RTD is a scam. Lock whole time
    May 2009
    Deer Park, TX
    26
    Is there a way to unscramble the OS? Maybe with Hex editor?
    Quote Originally Posted by 1bad03snake View Post
    I mean if you know what car its from you can narrow down the list of potential OS's significantly, if you have a hex editor, you could take an unscrambled file and see where the OS name is stored. Then it would be a game of chance just trying OS ID's that you've found.
    I don't know if that would work, I'm shooting from the hip here, there may be more layers of security, but I kind of doubt that its all that complex.
    I have absolutely no idea what I'm doing
    Mar 2021
    Pompano Beach FL
    478
    Cant speak for Fords but on GM and Dodge if you do a new read with the MPVI it will pull the file with no issues.
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
