What is "??? - 16"?
What is "??? - 16"?
* 0 - Driver Demand
** 1 - Transmission torque truncation
** 2 - Traction Control
** 3 - Vehicle Speed Limiting
** 4 - Engine Speed Limiting
** 5 - Anticlunk Tipin torque limiting or Tipin rate limiting
** 6 - Tipout torque
** 7 - Transmission Shift Modulation
** 8 - Engine Oil Over temperature
** 9 - Target N
** 10 - Powertrain Limiting Protection FMEM Limit
** 11 - ETC FMEM - RPM Guard
** 12 - PATS
** 13 - OSCMOD
** 14 - Speed Control
** 15 - Transfer Case Torque Limit
** 16 - Torque Based Decel
** 17 - VDE
** 18 - Engine Indicated Torque Limit
** 19 - Engine Combustion Stability Torque Limit
** 20 - HEV Torque Reduction at engine start or stop
** 21 - HEV Tipout Torque Reduction
Remote Tuning [email protected]
Where do you get that from?
^reliable source. its correct. currently Eric is on leave i believe
That list is correct.
Eric Brooks
HP Tuners, LLC
coyotetqsource.xlsx
Put the Sultan's post into a spreadsheet for downloadable reasons.
"I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
Does this list is valid also for Driver Demand Limit Source and also for Spark Source?
Eastern and Central Europe American Muscle and Harley-Davidson tuning
www.hd-customs.pl
http://www.facebook.com/hdcustomspl
Those two tables are listed under the tools tab in Live Link.
2012 Mustang GT with S/C
4Runner with S/C
Turbo/NOS Hayabusa - 320RWHP
OSCMOD- what is this? sorry to dig this up.
Oscillation modulation, used to reduce drivetrain oscillations by modulation of engine torque.
The shuffle switch under electronic throttle disables the logic that is used to determine and reduce these oscillations.
I’m hitting a Transfer case limit that it floating the throttle completely on a 2015 Mustang 6R80 any help on what I need to change. I’ve already have the gears set to 8,500 rpm and raised max torque 3 to 1106lbft
The minimum is 0.000 and the maximum is 1.000, but sometimes they have a fraction, 0.750, which means? Does it stop three quarters or does it allow three quarters?
anyone find torque source 22? Hitting that on a mustang right now
I think 22 is idle speed control.
Post the log and tune. That is an odd one to hit on a Mustang
Eric Brooks
HP Tuners, LLC
22 is idle control, 21 is HEV Tipout Torque Reduction.
