Results 1 to 9 of 9
Thread: E85 non sensor
    E85 non sensor
    ? WILL e38 ecm run straight e85 will out a sensor ? i changed stoich from 14.62 to 10.004 , Now the car will not run but about 5 min then shuts off, I know i can use sensor and pin 40 ,but i was going straight e85 all the time .THIS method worked on 0411 ecm
    learning
    5BA8
    3,604
    Yes. Only need for a sensor is if you want to run flex fuel. If your fuel never changes, set your stoich and start tuning.
    email=[email protected]
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    259
    Yes it can run without the sensor. What did your EQ ratio look like when idling? Also what percentage e85 did you add and how much. How much gas was left in the tank?
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
    2,991
    Unless your buying race E85 from like VP racing you going to get an inconsistant mix of E85.
    I've seen between E55-E78ish out of the pump.
    Using a sensor is a much better option.
    Tuner at PCMofnc.com
    Mar 2021
    259
    Agreed but I also ran this way for like 10 years back in the day before flex sensors on my DSM. Then did it in my CTS-V1 for a few years. I would find a good gas station that is consistent like Kum and Go in my area. E70 all year long. Also would tune WOT to e85 that way if I got something with more gas it just runs richer.
    2,991
    Same.. but with the sensors available there is no reason not to use it. If you can't afford a sensor just wait on the whole project.
    10-4
    learning
    lol buying sensor is far from problem This a play toy ,and i got hook up on E85 .MY turbo truck and my ls swapped s10 are straight e 85 . i get e 85 so Quick and i just trying use all i get
    learning
    Mar 2021
    259
    Quote Originally Posted by tww$ View Post
    I got the hook up too! His name is Kum&Go!
