I tried to get info on this else where but no response yet. So I'll ask the tuners here! For my 2023 ZL1 A10, I both the DSX Flex Fuel kit and the JMS Fuel Max Booster kit (and will be getting a Flex Fuel tune as well). But, I'm wondering where the issues start showing up related to not enough high side fuel pressure. If I understand it right, that's where the issues are related to running a mix or straight flex fuel. I've attached two HPTuners data logs and have highlighted the fuel PSI etc. They both show demand and the actual when running 93 octane (no flex fuel). My question is: Is there a way to determine from the data logs attached, if my high side fuel pressure will be sustainable based on the demand request once I mix in flex fuel? In other words, I'm trying to determine what Fuel PSI is required to run say E30 to E60+. I do have the JMS Fuel MAX system and will install it, but I'm curious at what point do you see your running out of pump vs having enough when mixing in flex fuel?
