Last week I dyno tuned a customer's 2003 Silverado 2500HD with 6.0. The truck was stock and the owner was mainly looking for better fuel economy, but was happy to get more power as well. I made the following tuning:
- Removed speed governor
- Increased spark advance in the partial throttle area of the 2200-2800 RPM columns until the dyno no longer showed torque gains
- Increased spark advance in the WOT areas of the map from 3200 RPM on up
There was an unusual issue that we had where high speed flashing would fail, so I pulled a few of the common fuses to no avail (the stereo was factory, fwiw). I decided to proceed with the slow method of flashing. One of these times when attempting to flash the computer bricked, so I disassembled it and grounded the reset PIN and was able to write-entire and get it working again. Upon the next write attempt, the computer bricked again and could not be recovered by using the reset PIN, so I took another P59 off of the shelf and installed it in his truck and did another write-entire. The truck worked great and the tune was complete. We drove the truck on the street and the owner was very happy.
He hooked up his travel trailer and went on a trip and reported to me when he returned that when he had the trailer hooked up that the truck would not go into overdrive even when tow/haul mode was disabled, and upshifts were extremely hard! He says when driving it with no load that it runs just as good as it did when we test drove it after the dyno.
I have not yet ridden in it while pulling a trailer, but I am very confused about this since I did not make any changes to the shifting any other transmission settings. I have attached both the original unaltered tune (AsFound), as well as the final tune (V2). If anyone has any ideas that might help identify what's happening here I'm all ears.
AsFound.hpt V2.hpt
