Results 1 to 3 of 3
Thread: Ba XR8 stock file needed PLEASE
    Mar 2020
    Hi Team, i am after a stock file for a BA XR8 with a 4 speed trans, or even a manual file will also work, i recently purchased a ba xr8 and having issues with the STFT on bank 2 adding fuel, and its using alot of fuel, so id like to compare the files as mine has been tunned and wondering if there is something in the background, also no air leaks from manifold i have done a smoke test fixed the PCV hose that was the only leak.
    Jan 2019
    Australia
    82
    Also check the O2 voltages to ensure they are switching properly and not hanging. From what you've described it sounds like you have a bad O2 sensor.
    Mar 2020
    Hi jason, thankyou for your reply, i have been mia lately hahaha this car is doing my head in hahahah its also not kicking into "overdrive" like the lock up in 4th not activating i just dont know what unlock and lock setting need to be changed. Ill log into this thread on my pac and see if i can get the attachment u sent
