Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 194
Thread: What is dynamic airflow
  1. #81
    Mar 2022
    Indiana
    3,038
    I hope post processing isn't required. I'd like this to be accessible and simple to implement for everyone.
    The formula is extremely simple.
  2. #82
    Mar 2022
    Indiana
    3,038
    Why couldn't it be:
    slope(MAF) <= 10 & slope(VVE) <= 10
    The user defines the slope function. Set to Percent with Period being something like 125ms (k timestep)? Do this for each airflow parameter.
    Someone translate that to a complete formula please. What would that look like?
    Thing is slope can't be determined for a point. Maybe the slope function does some sort of evaluation in a piece-wise interpolation/extrapolation fashion around a point. If slope requires 3 data points to evaluate for just one (slope of middle point) then that might be problematic.
  3. #83
    Mar 2022
    Indiana
    3,038
    Something like this I think. Haven't tested it.
  4. #84
    Mar 2022
    Indiana
    3,038
    Well. It's filtering something. Looks like it works.
    The graphs for DynAir_UMAF, DynAir_UMAP, DynAir_SS are operating in a Boolean fashion. Conditions met = TRUE = 1. Kinda cool. It's showing where steady state is for UMAF then for UMAP, and when both are TRUE it's shown at DynAir_SS
    What I want is to plot the actual DynAir value when the condition is true, but I haven't figured that out yet. If anyone can tell me that part (or how to even do a fucking <= in scanner) I'd be happy. See the expression? I tried [Dynamic Air] IF <expression>, but that didn't work at all.
    This is all preliminary stuff. Still have to verify that the slope filter is functioning the same way as what I plotted before. I'd have to take the log, python it, VCM Scanner it, run checks. I have to attend to other things right now.
  5. #85
    Jul 2020
    VIC Australia
    1,185
    In out and about, but can run it over a log tonight
  6. #86
    Mar 2022
    Indiana
    3,038
    I don't think it's working right, but it might still be an improvement. This log is pretty steady, as far as the "steady pedal movement slow RPM change" criteria from before, yet high slope changes are being filtered. Just doesn't quite look like it's doing an actual 0.1 slope. I'll keep working at it, but I'm glad to get a second opinion.
  7. #87
    Mar 2022
    Indiana
    3,038
    Nvm about stopping just yet. I was so close I could taste it. This is more like it.
    k = 0.012
    Gain_const = 0.1
    Code:
    The formula for determining when steady state airflow conditions occur and to filter as such is
    Poll [DynAir] if {(abs([MAF(k)]-[MAF(k-1)])/[MAF(k-1)]))/(k-(k-1)) <= [ECM 13432]} && {(abs([MAP(k)]-[MAP(k-1)])/[MAP(k-1)])/(k-(k-1)) <= [ECM 13432]}
    becomes the simplest calculus
    ... if d(MAF)/dt <= [ECM 13432] && d(MAP)/dt <= [ECM 13432]
    where d/dt is evaluated over polling rate = 12ms and [ECM 13432] becomes 0.1, simplifies to
    ... if delta(MAF)/.012 <= 0.1 && delta(MAP)/.012 <= 0.1
    where MAF is Mass Air Flow and MAP is VVE in terms of MASS FLOW RATE (g/s, lb/h, etc.), <= is relegated to <, translates to VCM Scanner user-defined Math Parameter format as
    ((ABS([50040.71]-[50040.71.shift(-12)])/[50040.71.shift(-12)])/.012) < 0.1 & ((ABS([2311.71]-[2311.71.shift(-12)])/[2311.71.shift(-12)])/.012) < 0.1
    Still needing that <= operator in scanner format Would be kind of ridiculous if it took a whole expression appended to this one as an OR that uses only the = sign.
  8. #88
    Jul 2020
    VIC Australia
    1,185
    The dynAir_ss filter looks good based on your screen shot. Looking forward to having a play with it.
  9. #89
    Tuning Addict
    6,877
    Only way I've been able to <= to work in the scanner is like this. Just grabbed one of mine where I'm logging spark from a given point to another given point. Don't know if this will do what you want though. You might be able to do it like this (whatever) < (whatever) and = (whatever) You have to use the and's...
    [14.161] > 35 and [14.161] < 55
    ~Greg Huggins~
  10. #90
    Tuning Addict
    6,877
    This is a slope function I had for plotting injector tip temp for logging - not my formula, but it does work.
    [50090.156.slope(1000)]<1 AND [6215.242]<140 AND [6215.242]>117 AND [6001]>10 AND ([6310]=0 OR [6310]=1 OR [6310]=6 OR [6310]=7 OR [6310]=9 OR [6310]=14) AND [50116.155.avg(500)] = 0
    Also if you think about it you really don't need the = to part. You can just use a number just under or above that number so it will start with the (=) number.
    ~Greg Huggins~
  11. #91
    Mar 2022
    Indiana
    3,038
    Haha yeah I see that OR statement. I agree < should be sufficient.
  12. #92
    Jul 2020
    VIC Australia
    1,185
    SiriusC1024
    Can you confirm this is what you want a 2nd opinion on?
    Code:
  13. #93
    Mar 2022
    Indiana
    3,038
    Duh. To graph DynAir at steady state just multiply DynAir by the Boolean expression. If TRUE, DynAir * 1 = DynAir. FALSE, DynAir * 0 = 0.
    It's pretty cluttered. Couldn't find any way to do a scatter plot without the lines.
    I created a new user defined math expression with DynAir * (filter). A histogram would use the filter exclusively. 0's wouldn't be included in the averaging function where filter criteria fails. Where it fails the data is ignored.
  14. #94
    Mar 2022
    Indiana
    3,038
    Code:
    That's it. Why did you find an error?
  15. #95
    Jul 2020
    VIC Australia
    1,185
    It runs. Needs some time on it, it's a bit too sensitive in it's current form.
  16. #96
    Mar 2022
    Indiana
    3,038
    It appears that when HJ 1 and HJ 2 =1 then SiriusC1024 = 1? If so then it's not working that way.
    You're using the filter with MAF and MAP in terms of mass, like g/s?
    Mind sharing the file you're using right there?
  17. #97
    Jul 2020
    VIC Australia
    1,185
    HJ 2 filter
    Code:
    [2320.71.slope(1500)]>-10 and abs([2320.71.slope(-200)])<1.6 and [6215.241]<60 and [2517.161.avg(500)]=0 and [2517.161.avg(-500)]=0 and ([6310]=9 OR [6310]=14 OR [6310]=15)=0 and [50072.slope(2000)]=0 and [50072.slope(-2000)]=0
    log is the longer version of the snippet I attached the other day
    https://1drv.ms/u/s!Atuxgi8rpo3Vm5YS...VTcNg?e=140Rea
  18. #98
    Mar 2022
    Indiana
    3,038
    What time interval is in that frame posted?
  19. #99
    Jul 2020
    VIC Australia
    1,185
    10s
    6m09s into the log I linked you to.
  20. #100
    Mar 2022
    Indiana
    3,038
    There's something going on with the way UMAF Boolean is being calculated. Hold on...
