Results 1 to 5 of 5
Thread: 2016 GT throwing codes P064D and P064E
    Oct 2015
    12
    Just installed a Gen3R supercharger. Starts and runs on the VMP tune they sent but is throwing these 2 codes and running in open loop fault. Just replace both front o2 sensors this morning with not change. Anyone have any other thoughts other than bad ecu possibly?
    Advanced Tuner small tuner's Avatar
    Nov 2015
    272
    inspect the o2 sensors extension if you have them, they could be the issue
    Turbocharged COYOTE
    PM for E tune / Remote Tuning
    [email protected]
    Oct 2015
    12
    It's had extensions, I removed them and install new o2 ntk 27063 with no extensions. Still the same problem. Also resistance tested the wires and they where good.
    Oct 2016
    Poland
    1,777
    This is heater code, so can be a fuse. Check power supply fuse for that circuit.
    Oct 2015
    12
    Check fuse and power supply. All where good.
    Got a new ecu and that fixed the issue.
