Results 1 to 12 of 12
Thread: Wideband keeps disappearing
    Dec 2014
    25
    I?m trying to tune a 98 SS. I?m using a AEM wideband. I used the serial input I have the white wire on pin 1 and the same ground is being used for the wideband as the interface on pin 5. Everytime I start the scanner the wideband disappears from the display. If I insert the analog input 1 it?ll display afr accurately but nothing works in the graph and the graph is Set up for lambda. Anybody have any idea what I could have done wrong ?
    28,319
    are you logging it in the channels? I would start there
    Dec 2014
    25
    I am. I have map and maf frequency and the serial version for the aem in the channels. It shows them in the channels until I start logging.
    Did you ever figure this out? I am having the same issue
    Sep 2018
    213
    I use to have this same issue. The serial to USB cable was the problem. I forgot the chipset name but they make a few different kinds that convert the signal. The more expensive one is the kind I needed. I'll look later tonight and let you know.
    Another thing I had to do is , start the car, wait for the wideband to warm up than hit connect and record. This would keep it from disappearing too.
    Found the issue, 100% my fault
    I guess I accidentally deleted the PID from my channel list. When I re-added it, I didn't follow the correct procedure. Since I'm using the analog input, I had to select the input (INPUT 1) and then transform the channel to my LC-1 wideband. Doing this solved the issue
    Nov 2022
    17
    Quote Originally Posted by momotunes View Post
    Which chipset did you use?
    2005 Silverado 2wd Crue Cab, Daily Driver
    2005 370" LQ4, BTR Truck Torque Cam, 202/202, .511/.511 111
    LS6 Springs, LS7 Lifters, Trunnion upgrade
    Speed Engineering HAI, Stock exhaust with 3" I/O Flowmaster
    New 4L65E
    2005 Cadillac CTSV TT, Too much to list.....lol
    8,087
    Quote Originally Posted by 54inches View Post
    Why don't you clarify which gauge you have, on what vehicle, and what method you're using for the connection? You've posted in every 'wideband disappears' thread you can find, it seems like you may be looking for solutions for different hardware/connection type than what you have.
    Nov 2022
    17
    I can do that.
    Truck in sig. Gen 3 LS P59
    AEM 30-03
    Well since MOMO was talking about a serial to USB connection, I thought that was clear, but for you I will clarify. I am asking about a serial to USB cable.
    I only have one connection for one vehicle and looking for solutions. Yep. Last time I used a forum, that is what it was for.
    I am also quadruple checking all of the research that I have done to make sure I am not missing anything.
    Also, I have not posted in EVERY "wideband disappears" thread that I can find. Some of them are repetitive and do not pertain to my setup.
    Speaking in absolutes makes you look like an asshole.
    Thanks for your help and I hope this calrifies everything for you.
    New 4L65E
    1,624
    Close enough to “all”.
    8,087
    30-03 is not a part number. 30-0334 is the CAN one for CAN-based vehicles - though it can do analog/serial but only if you add wires to the connector, it doesn't do it unless modified. 30-0300 is analog/serial/AEMnet, 30-0310 is analog/serial/AEMnet but without the gauge (controller only).
    Being pedantic is a lot more effective way to solve a technical issue than being sloppy and vague.
    Nov 2022
    17
    You're so cute.
    Context clues are not your friend are they?
    Thanks for your help!
    New 4L65E
