![Quote](images/misc/quote_icon.png)
Originally Posted by
racemonkey
You're here to sell, I get that. But, don't post dishonest information to do so.
I never said anything about 8800 RPM, with limiters removed the RPM should be in the 8300-8400 range. You definitely should not be running 8800 without retainers and probably springs.
"rest is skill" come on, outside of boost/cam/nitrous, timing is the only other way to add power, with fuel ratio having a very small effect if you're way off.
Why would you need a gps datalog? Stock AFR will 13 +/- 0.2 at WOT, this target is even shown in the stock map. I know you know this so I'm not sure why you're pretending it's not true.
