Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: Hemi with Procharger WOT by itself
    Nov 2016
    Austria/Europe
    46
    Hallo, I but an Procharger to my Hemi, with smooth boost BOV, and ever since, the TB will go to WOT while crusing very often. Anyone an idea what could cause this? TB was changed, no difference?
    Mar 2021
    Pompano Beach FL
    279
    Tune issue, best to try and log it and post it here
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Nov 2016
    Austria/Europe
    46
    Thank?s, I will be able to post a log on Monday I hope
    Nov 2016
    Austria/Europe
    46
    I don't know when I will get a log from my tuner, but are these settings ok? Unfortunately the car 450 miles away from me.
    WOT Pedal Threshold, Pedal Wot and Throttle WOT are all set to 1,8V is that ok? Sensed map is enabled.
    Hope someone will help me on this settings.
    Btw, how can I post my tune or a log?
    Mar 2021
    Pompano Beach FL
    279
    Quote Originally Posted by 123gr View Post
    That is to low, should be 2.5-3.0v is where I set them. you can email me the info as well.
    www.n2speed.com
    [email protected]
    Oct 2021
    Allentown PA
    363
    [ECM] 44442 - FA WOT Pedal: Above this pedal voltage, the fueling algorithm considers the pedal to be a WOT request. , All our Boosted Tunes get 1.625V, brings in extra Fuel to keep things cool., NA open Loop, 1.0V, I use it to better control AFR,
    [ECM] 44390 - Throttle WOT: Above this voltage the throttle is considered at WOT. A lot depends on what Driver is expecting, if its a track toy or 90% of the time driver same with the RPM value, Manual cars can benefit if you set the RPM above 2500, Auto's I've found set it to 1k below actual convertor stall speed
    [ECM] 13530 - ETC Pedal WOT: Above this voltage the Pedal is considered at WOT by the ETC system. Tricky ,set it to low and it messes with Power % Requested and Expected pedal 1.85V is too low unless it's a track only vehicle.
    it's most likely an Airflow issues, you didn't have the issue before the Smooth Boost BOV ? or has it always some what did it.
    Only way for any one of use to get you the help you need is, post log and tune.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Jan 2022
    975
    what is 44390?
    Oct 2021
    Allentown PA
    363
    what is 44390?
    You might not have it, it started to disappear around 2011
    Last edited by rays04gtx; 09-03-2023 at 09:14 PM. Reason: Wrong year listed 1st time Corrected now
    Jan 2022
    975
    nope
    i do not
    Nov 2016
    Austria/Europe
    46
    Blower and Smooth Boost BOV came together. Got a tune to start the engine, and than tried email tuning to get the car driveable. The issue was already. Then the engine broke (been driving too much with bad tune). Brought the car to Germany, to a tuner with AWD dyno, ordered a new high quality 426 engine at BBP, waited one year, waited an other year till the guys im Germany got the car ready.
    Now the engine runs fine, was tuned at the dyno, but the issue with TB is still there.
    The tuner himself is taking part in Pro Mods, but maybe he is not so familier with Hemis.
    Aug 2017
    Quakertown PA
    483
    Engines are engines, g3 hemi operating systems are the issue,
    G3 Hemi Videos
    Nov 2016
    Austria/Europe
    46
    Quote Originally Posted by PurpleRam View Post
    I know this, just wanted to tell my story
    Aug 2017
    Quakertown PA
    483
    All good, if you can post the tune and a log with throttle Volts, air flow, accelerator pedal bolts , there’s some real experienced boost guys who lurk around here. And can help
    G3 Hemi Videos
    Nov 2016
    Austria/Europe
    46
    That makes me hopefull, as far as I see now, I will go and pick up the car next week. Than I'll make all logs necessary.
    Mar 2021
    Pompano Beach FL
    279
    Have you talked to the guys at Kraftwerks they are in Germany and specialize with the Gen 3 Hemi's
    www.n2speed.com
    [email protected]
    Nov 2016
    Austria/Europe
    46
    Quote Originally Posted by N2speed View Post
    I know Kraftwerk, but Steffen from Kraftwerk is off this week, will talk to him next week. But Kraftwerk has no AWD dyno.
    Mar 2021
    Pompano Beach FL
    279
    You can put the vehicle in 2WD And or pull the front driveshaft and run it that way, not a big deal
    www.n2speed.com
    [email protected]
    Nov 2016
    Austria/Europe
    46
    Mine goes to limp mode, even if the AWD dyno has no synchronized axles. So I think it will not work.
    Mar 2021
    Pompano Beach FL
    279
    that sounds like a tune issue, I have put many Dodge AWD vehicles on a 2WD Dyno with no issue
    www.n2speed.com
    [email protected]
    Oct 2021
    Allentown PA
    363
    Ich weiB, dass Steffen kein Fan von AWD-Autos auf seinem Prufstand ist, aber da Kraftwerk wirklich der einzige Laden in Deutschland ist, zu dem es sich lohnt, damit zu fahren, sind Ihre Moglichkeiten begrenzt, er sollte in der Lage sein, herauszufinden, warum Ihr Auto Code ausgibt. Ich weiB, dass er in der Vergangenheit AWD-Autos gebaut hat.
