Results 1 to 20 of 28
Thread: Pulling KR timing on WOT
    Tuner in Training biggmac4's Avatar
    Nov 2012
    31
    2013 supercharged RT, 392
    The log seems to be pulling timing on WOT even when the knock sensors aren't showing high voltage. We're seeing about 5psi max at 6k rpm on a fully forged 392 stroker 9:8:1 compression. Is there some kind of setting that's doing this since the car use to be 5.7 and now has more power? The car runs great It just won't take timing up top. AFR 11:5. The tune attached I removed a bunch of timing just to see what would happen and it still pulled some.
    Tuner in Training TaylorJ's Avatar
    Dec 2022
    Newtown pa
    22
    Not to be a total C.U.N.Tuesday type of chick, but did you pay for this tune ? the tune it's self is the issue , it's fighting it's self
    also it's almost 10 to 1 , what heads ? eagle ? What Fuel ?
    Engine Size is still 5.7, should up it to 6.4, you're no moving 6.4 liters of air through it.
    Nov 2012
    31
    Were would it be fighting itself? Yes 392 in 5.7 block , 110 race fuel eagle heads .
    Nov 2012
    31
    I didn’t think changing the engine size did anything. What does it do exactly?. Will it rescale things if I change it to 6.4?
    Mar 2022
    Indiana
    3,112
    If you change to the correct displacement that will make the aircharge axis of the spark tables correct.
    Nov 2012
    31
    Engine size or displacement? or Both? On displacement it says " Setting this value to anything other than the stock value will disable ESP/TC. ". If I just change engine size, I don't see any scales changed.
    Oct 2021
    Allentown PA
    363
    Engine size, , you won't see any scales change, but what does happen is the sub routines now understand why your using Air volume equivalent to larger displacement.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Nov 2012
    31
    Wow that did the trick. I have plenty of adjustment now. Thanks
    Aug 2017
    Quakertown PA
    483
    Quote Originally Posted by biggmac4 View Post
    Simple things can trip these up , make sure all your rpm scales match, start point and end point. EX Table 36547 starts at 512 and ends at 5792 while your PT spark table starts 512 ends 6496 may sound odd and I get flack from some of the "pros" for saying this , but when all these tables have the same starting and ending reference points , these ECU's work better, less odd ball issues creep up.
    G3 Hemi Videos
    Nov 2012
    31
    What table? "EX Table 36547"
    Jan 2022
    972
    think he means yer spark tables
    4462x
    Quote Originally Posted by rays04gtx View Post
    Definitely need customer to anti up for a 180 T-stat , Ambient air is almost 100F, where are you located ? judging from the Baro reading you're about 500 above Sea level.
    can't run this truck on 87 OCT now,
    remember what i was saying about getting the temps down before trying to tune spark, fuel, cam, knock sensors, etc ???
    if not yer gonna end up doing it twice
    Oct 2021
    Allentown PA
    363
    EX Table 36547 , EX = Example Table 36547 starts at 512 ends at 5792 .
    Basically the idea is , no mater how you want to scale the RPM axis , its a good idea to make them all start the same and end the same, exception it WOT , you can start that in the mid teens but as long as the end point is the same as all the other the ECU done's hunt around for Values to use when it transition from table to table.
    Jan 2022
    972
    those are cam tables
    did you try those tunes i sent to determine the phasers limits yet?
    Aug 2017
    Quakertown PA
    483
    Cam tables count , idea is the more uniform the scales are the less likely the ecu is to pull some odd ball values when it has to make a decision between what we reprogram it to do and it’s base protocols.
    G3 Hemi Videos
    Nov 2012
    31
    I found issue testing last night. Knock Sensor 2 is reading high V. Willing to accept the consequences We disabled the knock sensors for some testing and the car ran great. No noticeable pinging. Ill look into getting that fixed. For those who are running forged blown cammed motors with headers around what Voltage on the knock sensors are you guys seeing?
    2013 Challenger R/T, forged 392 stroker, 5.7 block, TR606 6-speed, TorqStorm supercharger, intercooled, 5psi, Getrag 3:73 rear end.
    Jan 2022
    972
    some will say 1.5v but there are too many variables
    the engine is supercharged
    the supercharger is centrifugal (more boost at higher rpm)
    you disabled the vvt (cam is always at max advance)
    ___________________________________
    if you add all that up the sum is cyl pressure
    did you cc this engine?
    if so what was the static compression ratio???????
    *and which 100 octane fuel are you running?????
    Aug 2017
    Quakertown PA
    483
    1st question is which Alloy ? 2618 or 4032? 4032 pistons are quieter , looking at the Zeros log your Idle at 180F is quiet , hovers around .35+/-v so I'm guessing 4032s (I could be wrong)
    I do tuning for a guy who has a Drag pak clone (and a real 2015 DP car) 354 ci all forged with 2618alloy pistons, car runs a 2015Hellcat ECU , at WOT it'll pull as much as 2.5-3.5v at 180f operating temp, at 165f operating temp (160F t-stat) it pulls 3.0-3.75v@ WOT . During warm up it's LOUD idling at 1.5-1.6v no matter the T-stat. once it gets to 180 it's around .65+/- .10v @160f it's .90+/- .15v
    Looking at your log zeros your fine with a 2.5v min, I'm going to take the Tune you posted earlier in this thread and rework it , it'll be close to what you have but I'm going to change some things that I can't explain here and my dam Phone broke today so I can't do a Video like what I did for the Ram/VVT thread .
    G3 Hemi Videos
    Aug 2017
    Quakertown PA
    483
    Bank 2 is ALWAYS louder because it's the thrust side.
    G3 Hemi Videos
    Aug 2017
    Quakertown PA
    483
    Next set of logs you do , log the Accelerator Voltage and Throttle Voltage , the %'s are not as important , reason being, spark,Air flow,Fuel are all triggered by Voltage not percentage,
    G3 Hemi Videos
    Nov 2012
    31
    Quote Originally Posted by PurpleRam View Post
    Here is from today with some ramp up to see what it does.
