Page 4 of 4 FirstFirst 1234
Results 61 to 63 of 63
Thread: 2015 Ram 1500 no start when VVT enabled, disabled starts fine
  1. #61
    Aug 2017
    Quakertown PA
    483
    It's better, it's working stick with it.
    G3 Hemi Videos
  2. #62
    Aug 2021
    Yorktown VA
    200
    This should make it even a touch smoother. Just made a few adjustments on a couple spark tables to smooth things out a touch....
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
  3. #63
    Oct 2021
    Allentown PA
    363
    you both are leaving too much power on the table, even on 87OCT
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
