Thread: 2004 chev suburban throttle tuning
    Nov 2021
    28
    I have a 2004 5.3 from a suburban that I swapped into a 81 k5 blazer when you push the throttle to wot from a standing start it feels like a older car with a carb when they bog, I feel that it is some kind of lag between when the pedal gets pushed to the floor and the ecm sends a signal to open the throttle body what tables should I be looking at to tune this out?
    13,604
    Post the tune and logs.
    SoCal
    1,604
    Sounds like it may be the OS that has an factory update for a "throttle progression" issue. The new updated software fixes the problem and doing a compare from before and after you can see the areas that are changed regarding the throttle. Pull the tune and check for updates.
    https://tis2web.service.opel.com/tis2web/
    Nov 2021
    28
    Ok I will and I will post the tune and a log tomorrow when I am working on it
