Results 1 to 9 of 9
Thread: Gen 2 Roush OS on FRPP Control Pack - Crank No Start
    Tuner evolmotorsprt's Avatar
    Aug 2018
    Salt Lake
    115
    I have a FRPP Gen 2 Coyote and Control Pack with a 670HP FRPP/Roush Kit in a 32 Roadster I'm working on. Car starts and runs with the FRPP OS. I swapped to the Roush 727 Manual OS and it would crank but not start.
    Car has a return style fuel system. I matched everything regarding fuel with the FRPP File. It seems like the Roush OS Doesn't activate the fuel pump and doesn't give any ipw during cranking.
    Has anyone run the Roush OS on a FRPP Control Pack?
    1932 Ford Coupe FRPP Startup More Fuel.hpt
    2017 Roush 727 File Merge.hpt
    Oct 2016
    Poland
    2,042
    Log torque source
    Aug 2018
    Salt Lake
    115
    Log torque source
    Thanks for making me feel dumb, lol. I should have caught that. The torque source its PATS. Considering I have PATS disabled in the tune, is there any reason it would still have a security issue?
    Oct 2016
    Poland
    2,042
    Somehow Roush tunes will trigger PATS on some PCM's - most likely non US based cars.
    You need to work on your stock read. Hit me up if you need any service.
    Jul 2020
    43
    There must be a work around for this since it's the flash that is causing this issue no?
    Feb 2017
    TX
    760
    He needs to tune his stock file instead of using roush.
    Dec 2010
    Asheville, NC
    11
    Production OS require PATS to be deleted from the ECU and from the calibration - you can only do the latter with HP.
    Control Pack has no PATS provision and skips all of that.
    Jul 2020
    43
    If you write a Roush OS to a contorl pack it still enables PATS, even if you ahveit disabled in the proper tab. The control pack doesn't have PATS and yet it is enabled with the Roush OS
    Oct 2016
    Poland
    2,042
    Quote Originally Posted by mnbf69 View Post
    Ypu can send PCM to me i can disable PATS for good even with Roush os
