After a lot of work and finding out that our TCM and ECM/TCM computer were not compatible we got that figured out. Working through tuning and we are having some issues with throttle response. We get the P0606 code. A little bit of throttle and lightly pressing there isn't an issue. However, you can go past 30%(estimated) or goose it and if you do the CEL comes on and the throttle pedal become unresponsive. If you reset the CEL then it returns to normal until you do it again. You can literally drive it up to highway speeds with some pedal and it shifts great and runs excellent. So, not sure what is happening here. Below is a copy of the file. Thanks for any input.
