Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: E67 V6 engine Swap VATS issue
    8,036
    I think I'd follow the steps for P0335/P0336 before I started disassembling the engine to check the highly unlikely things.
    I'm not going to go back and look it up again, but it should tell you to check for the correct voltage on the reference pin, and that the ground is good, and that the signal wire is connected back to the ECM and that you can force it to read RPM counts by momentarily grounding the signal wire. If you can force it to read (fake) RPM, then the sensor is bad.
    1,585
    Yeah, I wasn’t meaning to check the ring if a thorough check of everything else hasn’t been done.
    8,036
    And there could've been a tune setting wrong and the new crank sensor introduced a second failure, but the settings have since been fixed... new sensors should always be treated as defective until you can prove otherwise.
