View Poll Results: 5.7 single turbo 270 comp cam
Voters
2. You may not vote on this poll
  • idk
    2 100.00%
  • idk
    0 0%
Multiple Choice Poll.
Results 1 to 8 of 8
Thread: 2012 Dodge Charger 5.7 Turbo
    May 2023
    5
    Question 2012 Dodge Charger 5.7 Turbo
    Hello i have an 2012 Dodge Charger 5.7 with a single turbo. I have the 5 psi watsegate spring in now and needing help or someone to look over my tune. I got it started but it surges bad until it cuts off. It has a 270 comp cam everything else is stock. Im new to hp tuners HELP!!!
    May 2018
    Germany
    618
    did you dial in the cam before you install the turbo ?
    Search in the forum, the cam must be adjusted by airflow and idle controls.
    May 2023
    5
    Quote Originally Posted by f.creek-ranch View Post
    yes i did. Here is the current file i need assist with.HemG Stock Tune Copy 270 v2 Turbo2.3.hpt
    May 2023
    5
    i got it to idle even drive but i have no psi/boost & my boost gauge reads negative and have no torque/power to the wheels like before was installed. it has the 3 bar map sensor stock injectors & fuel pump on 93 octane.
    Mar 2021
    Pompano Beach FL
    466
    Besides a tune you need bigger injectors and a BAP or larger fuel pump
    www.n2speed.com
    [email protected]
    Dodge And GM Tuning Support
    Diablosport CMR | HP Tuners
    May 2023
    5
    i know thats coming .. i was trying to at least get a tune for my stock injectors for now with the 5 psi waste gate spring i have in...
    Oct 2016
    Poland
    2,034
    We can help you out with that. We boosted many 5.7's.
    You need bigger injectors and that is a must, BAP is not needed for 7psi.
    May 2023
    5
    2012 Dodge Charger 5.7 Single Turbo
    update i have hellcat injectors and 400 walbro pump installed now. still needing help and my a/f ratio is slightly off.HemG 5.7L Stock Comp270Turbo 3bar Revised1.1Tans.hpt
