Page 2 of 8 FirstFirst 123456 ... LastLast
Results 21 to 40 of 145
Thread: Idle Airflow w/ and w/o clutch engaged
    Strange because he says he did it for FIC (Connection) yet the numbers between both sheets do not match. I'd love to know which one is more accurate.
    For comparison, the offset at 40kPa and 14.0V is 1.0796ms in the one table, and 0.263ms in the other table.
    • 2001 C5 Corvette (625rwhp - Procharger, LS6 heads, Torquer V2 cam)
    • 1991 Volvo 940 - 2JZGTE (600rwhp - PT6466, HKS 272 cams)
    1,627
    There is always a chance that they changed design, suppliers, etc.
    Mar 2022
    Indiana
    3,138
    FFS I hate that they have the same name abbreviation. I said Clinic in the Intro Tab. It's Connection. Edited the previous.
    I knew what you meant. lol
  6. #26
    Mar 2022
    Indiana
    3,138
    I just emailed AACorvette and FIConnection. DM'd Greg Banish. Hope they'll help out.
  7. #27
    Mar 2022
    Indiana
    3,138
    From AACorvette:
    I'd use what FIC is now using. It's been updated.
    Thanks, Andy Green
    Owner / CEO A&A Corvette Performance
    477 Lambert Street
    Oxnard Ca. 93036
    805-278-4107
    WWW.AACORVETTE.COM
    WWW.AASUPERCHARGERS.COM
    NOW PARTNERING WITH AFFIRM TO OFFER INTEREST-FREE FINANCING!
    A+ BETTER BUSINESS BUREAU ACCREDITATION
    YOUTUBE- CUSTOMERS CARS- REVIEWS
  8. #28
    Mar 2022
    Indiana
    3,138
    That's a huge difference in Offset and SPA. Wonder what the background is on the update?
  9. #29
    Yeah, I was wondering the same.
    I was also told by Josh @ FIC that if I wanted to upgrade to Bosch (I think) injectors, they would be much more reliable in terms of numbers than the Siemens Deka (which are middle of the road supposedly).
  10. #30
    Just did a nice long log and noticed that when I allowed it to idle long enough, the STFTs would drop to about -16% after 15 seconds and then the narrowbands would begin to switch.
  11. #31
    5BA8
    3,640
    Where's the data log?
    email=[email protected]
  12. #32
    I'll post it later if I get a chance. Not looking for any more criticism or critiquing on it as I think I have enough pointers as to what to look at. Just wanted to make a note that it did, in fact, lean itself out and I was surprised the idle fueling was that far off.
  13. #33
    Mar 2022
    Indiana
    3,138
    What did you do different?
  14. #34
    Let it idle long enough for the STFTs to go low enough. Now to start some tweaking.
    Here's the log.
    STFT.hpl
  15. #35
    Mar 2022
    Indiana
    3,138
    FIC is asking if you're using the tall black LS1 Deka 60's?
    Or from here which one?
    https://fuelinjectorconnection.com/collections/ls1-ls6
    Would you mind posting the sheet you got from FIC so I can forward it to them?
  16. #36
    Mar 2022
    Indiana
    3,138
    Quote Originally Posted by phuz View Post
    Here's the log.
    Wow look at what the wideband is doing. 16.86 AFR at a commanded 14.68 with narrowbands switching about stoichiometric.
  17. #37
    5BA8
    3,640
    Here's the log.
    STFT.hpl
    Thanks for posting that. There's a couple interesting tidbits in there.
    1, it's a great example of why I don't care what a wideband reads in closed loop. Now that it's actually at stoich the WB is reading 16:1 on average. So regardless if it's not calibrated correctly or if it's just the nature of that cam, either way, there ya go.
    2, it still bottoms out at 1.8 ms IPW. It actually gets to 1.8 and the trims continue to drop a few percent. Would like to see what the actual on time is with an o-scope. There's no way they're idling at stoich at 1.8 ms.
    Something is definitely off in the injector data. Doing a compare to a couple other 01 stock files, several of the transient tables have been changed. They factor into total on time as well as the rest of the data. I'd put all of them back to stock. Then setup your data once you figure out exactly what you have.
    You'll likely have to redo the entire VE.
    Footnote: If your wideband doesn't level out at 14.6ish +/- around 1800-2000 rpm, light throttle, you need to calibrate it before you start WOT tuning it.
  18. #38
    Mar 2022
    Indiana
    3,138
    Actually, my fault, it's not stoichiometric. Switching at a slightly richer point (451mV = stoich). IAC is pegged, too.
    One way of correcting this is to stretch the Mode vs Airflow table out for the new idle airflow baseline required by heads/cam/exhaust.
  19. #39
    5BA8
    3,640
    Attachment 138192
    Doesn't matter. Close enough. I saw the switch points. 560 mv is not 16:1.
  20. #40
    Mar 2022
    Indiana
    3,138
    Yep nowhere near 16:1. In fact, the slightly richer switch point gives further evidence of the wideband vs narrowband error.
    Where is the wideband located on your setup phuz?
