Originally Posted by
aaronc7
The last picture "LTFT Airmass" looks pretty good to me. For the low kPa cells, it's probably commanding some very small injector pw value, that due to the injector deadtime characteristcs, it actually isn't firing at all or very little fuel-- so its running lean. That would normally be DFCO region of course. It's probably fine as is. Or you can increase the injector min pw tables little by little until they start to appear to be firing correctly with fuel. I wouldn't really expect this on stock injectors but who knows.
VE is a bit like, but like mentioned put them into a histogram that matches the calibration axis exactly so you can copy paste initial corrections in.
And for MAF tuning, put the corrections into MAF table axis/format so you can apply proper correction to it. Just a guess but it might need a little tweak in the airmass/hz range, but mostly looks good as already mentioned above. If it's having to add a lot of fuel at low load/airmass, high vacuum only then it could indicate a vacuum leak as well for the MAF side.
