Results 1 to 9 of 9
Thread: PLEASE help Data logs
    Sep 2023
    8
    when i log my scanner with afr on the computer that i used to log with i have wideband if i take that log even if i export it and email it to someone the wideband no longer there only on original log i tried exporting it then sending it through email same not there so i trying to send my logs to my tuner but losing wide during the email why or am i doing something wrong thanks for your help
    5BA8
    5,476
    Post a data log here.
    You probably have to save your channel config and email that along with your data log. But if you're using a current version of the software you shouldn't have to. I'd bet the person you're emailing the data logs to is using an older version. Just a guess though based on the very limited amount of information provided.
    email=[email protected]
    Aug 2023
    SoCal
    668
    Quote Originally Posted by Bristolmike View Post
    That channel [40101] has no data recorded in it. Are you saying that if you open it on your end you can see that in that same recording you sent on here?
    Robert Moreau
    TransGo
    5BA8
    5,476
    I see you're running it through your AC pressure sensor. You have to send your config file and your maths. Under Documents/HPtuners/ VCM scanner/Maths
    It won't just show up on the other end like if it was wired through the interface.
    Sep 2023
    8
    pics
    see the pics one is orig on on scanner the other was sent by email and loaded on different laptop
    5BA8
    5,476
    I get it. You need to follow my directions.
    Aug 2023
    SoCal
    668
    I see you are using a math channel to converter a reading you are getting through the AC pressure sensor. So you have to do like edcmat-l1 said and send both your config file and the math channel file for him to view it. Or he can make the math channel himsel on his end of course if you give the equation.
    Robert Moreau
    TransGo
    Feb 2022
    Washington State
    60
    Interesting error codes. AC compressor sensor; which makes sense and a VIN verification issue. Will vats cause the vehicle to run like the logs are showing?
    P1635 (Pending, Current)
    P1639 (Pending, Current)
    5BA8
    5,476
    Quote Originally Posted by chadtunes View Post
    If there's a VATS issue it won't run at all.
    Those are 5 volt reference codes. OP isn't logging the map sensor. Would like to know what that's reading. Other than that, looks like it's in open loop and it's running too cool. I'd imagine he has a 160 stat. Nothing LS should run that cool. These ain't iron headed small block chevys. This ain't 1983 it's 2023.
